  • SN95 4.6L Mustang Tech
Airbag Light?
  • Thread starter Thread starter StangJonGT
  • Start date Start date Feb 13, 2004
StangJonGT
1,329
Seattle
Feb 13, 2004
  • Feb 13, 2004
How do I turn off the Airbag light? My car was in an accident, and now has new airbags. The problem is the light has been on since the accident and hasn't turned off with the new airbags. I plugged them in and installed them correctly; I don't see the problem. Anybody know anything about this?
Jon
D
drizztkun
497
Montreal Quebec
Feb 13, 2004
  • Feb 13, 2004
it needs to be resetted, i would go and ask a tech at ford
StangJonGT
1,329
Seattle
Feb 13, 2004
  • Feb 13, 2004
Any Ford techs here? I was pretty sure it had to be reset, but I want to know the process.
Jon
J
JB9789
12
  • Feb 13, 2004
did you try just disconnecting your battery ?
jadesville
the polarbear conservation corps protects a polarb
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Feb 13, 2004
  • Feb 13, 2004
no, that doesnt work..its a code, however i am having the same problem, because my airbags were replaced from an accident as well...
AdRock
521
South Texas
Feb 13, 2004
  • Feb 13, 2004
It's odd that the people that replaced the bags didn't turn off the light. You willmost likely have to stop by the dealer and have them do it.
StangJonGT
1,329
Seattle
Feb 13, 2004
  • Feb 13, 2004
I replaced the bags myself, that is why I haven't turned off the light--I don't know how. And no, disconnecting the battery does not work.
Jon
jadesville
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Feb 14, 2004
  • Feb 14, 2004
they did it to me
OD
323
Calgary, Ab Canada
Feb 14, 2004
  • Feb 14, 2004
resetting the light is easy...
locate a grey connector under the glovebox, it isnt connected to anything, it is just stuck up there. turn the key to the on position and wait for the ENTIRE airbag light code to complete (3 flashes, pause, 5 flashes for example) short out the 2 leads in the connector (2 outside contacts) hold it there until you hear beeps from the computer.
that should do it.
StangJonGT
1,329
Seattle
Feb 15, 2004
#10
  • Feb 15, 2004
  • #10
My light flashes indefinitely--when do I short out the connector?
Jon
StangJonGT
1,329
Seattle
Feb 15, 2004
#11
  • Feb 15, 2004
  • #11
Oh, and will this kill my airbags? I want them to work...
Jon
OD
323
Calgary, Ab Canada
Feb 15, 2004
#12
  • Feb 15, 2004
  • #12
short the connector out after the first airbag light error code completes, and no it wont kill the bags, it just simply resets the computer...
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
