Alignment, how to?
  • Thread starter Thread starter Mavrick
  • Start date Start date Jan 16, 2004
Mavrick
2,264
Collingwood, ON
Jan 16, 2004
  • Jan 16, 2004
Hey guys, i have to get the mustang front end aligned. It's pretty out of whack right now, seens how the previous owner never aligned it after he changed spindles etc. (had the car ripped apart)
Could anyone take me through how i can align my front wheels? I just want them to face straight, right now it's kinda like this \ / - i will get it done professionally so it's perfect, but for the mean time i'd like to try it myself.
Thanks.
stangbear427
2,401
New England
Jan 16, 2004
  • Jan 16, 2004
Is \ / the front view, or the view from above?
mysticfire5OH
72
Fort Wayne, IN
Jan 16, 2004
  • Jan 16, 2004
I just finished a swap and went through the same thing.
heres how i did it.
1. i put penetrating oil on the treads of the things that connect to the spindle and steer the car (sorry for all the technical terms..ha)
2.the next day i used a pair of vice-grips and a wrench to bread them lose.
3. take a tape measure (this requires two people) and measure either from the front and rear of the rotors (with the tire off) or from the front and rear of the tire.
4. get this measurement the same and unscrew the the things until they fit back into spindles without moving the spindles.
5.after installing them you may want to measure again
Hope this kinda makes sense
thats how i did it and it worked great for me so i could take to a professional
if you have any other questions just ask.
NIck
Mavrick
2,264
Collingwood, ON
Jan 16, 2004
  • Jan 16, 2004
heres how i did it.
NIck
Oh boy, LOL. I think you mean tie rod ends... and where did you measure from? Rotor to rotor?
StangBear427: That is a birds eye view, one wheel is actually pretty straight when the steering wheel is straight, then the other wheel wants to point inward.
stangbear427
2,401
New England
Jan 16, 2004
  • Jan 16, 2004
OK. You can get them the same by measuring from the tie rod ends to the rack bolts, and screw in/out the one that is way off. Then for getting your toe right: you can straiten out the steering wheel, and using a straitedge about two feet long, set it across the wheel so that one end is touching the ground on the rear of the car side of the tire and mark that spot on the ground on both sides. Then do the same thing, only with it touching the ground on the front of the car side. You can measure these two and screw each side in/out evenly to get them parallel. Remember, it's better to have them toe'd in a little than out. If none of this makes sense, I can draw a quick scetch and scan it in for you.
Mavrick
2,264
Collingwood, ON
Jan 16, 2004
  • Jan 16, 2004
Thanks for that.. i understand how to get the alignment straight, but how to adjust the toe totally boggled me.
If you don't mind drawing/scanning up a diagram, i'd really appreciate it.
Jeff.
stangbear427
2,401
New England
Jan 16, 2004
  • Jan 16, 2004
OK, I just learned how to use my paint program. You want to do the same thing on both sides of the car, and measure from driver side to passenger side A to A, and B to B. The longer your straitedges are, the more acurate it will be- like if points A and B are a few feet in front of and behind the front wheels instead of where I show in the dia.
95 5.0L
159
  • Jan 16, 2004
http://corner-carvers.com/forums/showthread.php?s=&threadid=13211&highlight=ALIGNMENT
Mavrick
2,264
Collingwood, ON
Jan 16, 2004
  • Jan 16, 2004
Thanks.. i'll have to get a buddy to help me try that out...
stangbear427
2,401
New England
Jan 16, 2004
#10
  • Jan 16, 2004
  • #10
That was a good post. Same idea, only way more complicated. Way more precise though, that guy won't need to go to the allignment shop- but he also could have had it done a few times for the cost of the tools... and I personnally would rather it be someone else's ass if my tires end up wearing funny.
D
DJiCE
117
Bloomfield, NJ
Jan 16, 2004
#11
  • Jan 16, 2004
  • #11
That drawing looks like a camaro ...
stangbear427
2,401
New England
Jan 16, 2004
#12
  • Jan 16, 2004
  • #12
Hey, it's my first time on paint1! cut me some slack!
Here, is this better?
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
