Alignment shims
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date May 15, 2007
65fastbackresto
1,229
AR
May 15, 2007
  • May 15, 2007
Anyone know if there should be the same amount of alignment shims on each side of the upper control arm?
I am considering doing the shelby drop and just kinda curious.
splinterddt
201
Florence, CO, U.S.A.
May 15, 2007
  • May 15, 2007
No, there doesn't. The amount of shims depends on how far your front end is out of alignment. After you're done with the Shelby drop you need to have a alignment done.
BornInAFord
199
Bend, OR 97701
May 15, 2007
  • May 15, 2007
If you do your drop, mark the shims when you take them out. They will go back in the same spots so your alignment won't be too far off when you take it to the shop. FYI: you usually can lose an 1/8" shim from each stack, though, to keep the static camber close as you won't need as many shims after the drop. Make sure to get a performance alignmentl like those for a Shelby, not the stock bias-ply alignment! 2BaV8 has the specs on his website.
Daniel
65fastbackresto
1,229
AR
May 15, 2007
  • May 15, 2007
I dont know what
I would do without you guys helping me, THANKS TO ALL, even the mean ones....LOL
1968 coupe global west upper control arm template
  • Butchd88
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 12, 2026
Butchd88
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
