C ColdBloodedVert New Member Mar 19, 2003 12 0 0 Wilmington, DE Sep 11, 2004 #1 Sep 11, 2004 #1 Need some help. I lost my instruction sheet and I need to know if someone has the proper alignment specs I should use. Thanks in advance.
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Sep 12, 2004 #2 Sep 12, 2004 #2 as i recall the street alignment specs are as follows; caster 3 degrees positive camber 1/2 negative to 1/2 degree positive toe in 1/8" max
