Alignment when installing SN95 spindles
  • Thread starter Thread starter 4000 Pounds of Iron
  • Start date Start date Mar 3, 2006
4000 Pounds of Iron
473
Nashville, TN
Mar 3, 2006
  • Mar 3, 2006
I'm about to install SN95 spindles that I found on a 1994 at the Pull-A-Part -- I can only assume that this will destroy any semblance of alignment that my car has right now. What can I do to get to the alignment shop without burning up my brand-new tires?
4k#Fe
onefstsnake
792
Northern VA
Mar 4, 2006
  • Mar 4, 2006
Well how much wider will the SN95 spindles make the front end?
Im thinking you should be able to make it to an alignment shop without messing up the tires too bad. Depending on how far away the shop is...
L
llwood
39
  • Mar 4, 2006
unless the align so so far off you can see it i would think you would be able to drive to the nearest shop. I dropped my s10 4 inches in the front and put new spindles on it and it was fine going to the shop
4000 Pounds of Iron
473
Nashville, TN
Mar 4, 2006
  • Mar 4, 2006
I'm just worried that where the tie-rods attach is different enough to cause a drastic toe change. Anyone have direct experience with this?
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Mar 4, 2006
  • Mar 4, 2006
Yes, you will need to readjust the tie rod ends after you put the sn95 spindles on. When I did my conversion, I adjusted the spindles by eye until both of the front wheels looked lined up. That made it good enough to drive the car 5 miles to the shop to have it aligned. Good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 4, 2006
  • Mar 4, 2006
I think to get close I had to turn out the tie rod ends about 12 or 13 turns.
D
Daggar
3,902
  • Mar 4, 2006
Yeah... it's not too tough. You can measure the distance between the front an rear edges of the tires and adjust accordingly to make it all good enough to get to the alignment shop.
Kabuki_notch
670
394
113
Rochester, NY
Mar 4, 2006
  • Mar 4, 2006
we adjusted mine at my house then i brought it to a shop and got it done they gave me a discount because when we adjusted it it was so close to perfect.
five-o-joe
  • Mar 5, 2006
You may as well check the condition of the ball joints as well as the inner and outer tie-rods before you pull everything apart. You do this by checking for excessive play by grabbing the tire and shaking it up and down to check the ball joints, then in and out for the tie-rods as you probably know.
I did the same swap to SN95 spec brakes only to get to the alignment shop and be told that all of the mentioned parts needed replacing. The silver lining was that I switched over to the shorter SN95 ball joints to eliminate the need for the stacked washers used to swap the spindles on the old ball joints. Also the outer tie-rods were replaced by a steeda bump-steer kit to compliment the improved steering geometry of the SN95 spindles.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
  • dan50
  • Jul 18, 2026
dan50
