  • SN95 4.6L Mustang Tech
alignment?
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Nov 28, 2007
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Nov 28, 2007
  • Nov 28, 2007
Ive had my car for about 6k miles and had to have the alignment done on it twice and now its out again but nothings loose or worn out
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 28, 2007
  • Nov 28, 2007
sounds like someone doesnt know how to do a proper alignment
post up your current specs
BCB00GT
420
Nov 28, 2007
  • Nov 28, 2007
Are the specs out of alignment or the tires wearing on the outer edge after the alignment? My only thought would be a bad wheel bearing causing the wheel to have play in/out.
98COBRA281
1,348
30
59
Nov 29, 2007
  • Nov 29, 2007
ill have to check
DTNODYA
831
  • Nov 29, 2007
Ball joints could also.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 29, 2007
  • Nov 29, 2007
or tie rods
R
Wow, Tire Issue on 2019
  • Rcdgl
  • Dec 30, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 11, 2026
Rcdgl
R
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
