Allignment or braking issue?
  • Thread starter Thread starter zehnderm
  • Start date Start date Aug 10, 2007
Z
zehnderm
  • Aug 10, 2007
I've got a 65 coupe that pulls slightly to the left when braking. They're stock drums that have recently been rebuilt. Is it possibly an issue with one of the brakes grabbing early or an allignment issue? If its a braking adjustment issue, I heard that drums are self adjusting and can be "adjusted" by braking while in reverse. Is that correct? Any help would be appreciated.
rbohm
6,698
550
204
tucson,az
Aug 11, 2007
  • Aug 11, 2007
the problem with stock drum brakes is that the pressure in the system under initial braking is unequal, and biased to the left front corner due to the shorter line run.
M
Muscleford
27
Streetsboro, Ohio
Aug 11, 2007
  • Aug 11, 2007
It sounds like the pistons on the right side may be hung up causing the brakes on the left side to catch first. When a car pulls the problem is usually on the opposite side from the pull. I doubt it is alignment if it only occurs when braking.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
