altenator wont charge
  • Thread starter Thread starter blue87lx
  • Start date Start date Oct 28, 2005
blue87lx
175
  • Oct 28, 2005
my car wont charge. the altenator light is not on. i just put a brand new altenator in still doesnt work. the altenater has a magetic field around it with the key on so i know its good. if i hold the rpms at about 2000 neither of my volts gauges will even move but they will go down if i flick on the lights or somthing. what/how should i check???
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Oct 28, 2005
  • Oct 28, 2005
Mine does the same but mine voltage hand goes up when i drive it and goes down when i turn on my lights. last time i had the problem it was my voltage regulator but i havent had time to get a new one!(other biggger probs right now)
HISSIN50
34
129
Oct 28, 2005
  • Oct 28, 2005
If the stock volt gauge is not working, I would want to check the 'switch and sense' wire out. If it is not connected, the alternator will not put out any juice.
Good luck.
blue87lx
175
  • Oct 29, 2005
my gauges work. they dont fluctuate up and down they just go down as the battery dies. after the lights are on for a while the battery is dead and i have to charge it. its a brand new altenator the onyl reason i bought it was cause i figured it was bad since the one i had on the car wasnt giving me volts either.
HISSIN50
34
129
Oct 29, 2005
  • Oct 29, 2005
Ok, I misinterpreted your initial post - sorry about the switch and sense wire comment.
Have you gone through the wiring connectors at the alt itself? The connectors tend to get old/burned. How about the fusible link on the alternator-to-solenoid cable? Is there a good connection of the charge cable at the solenoid?
I take it that you have put a meter on the alt charge cables to see what they are doing? Is there a voltage drop from the alt to the battery (if the alt even shows any volts)?
Good luck.
blue87lx
175
  • Oct 29, 2005
no problem dude it happens. ill figure it all out tomorow ill just have to get into it. thanks tho ill let ya know what happens
P
plainwrecknate
92
Fort Morgan, CO
Oct 29, 2005
  • Oct 29, 2005
you can do what i did... i was having problems with my alternator last week and didn't want to tinker with it because it was 27*F outside and i don't have a garage. i took it to autozone, we checked it in the car... it was at -20 amps!! so we took it out, put it on their tester, three times and it failed every time. when we took it out, there was a burn mark on it and the pigtail was fried.
come to find out, the guy i bought the car from, who told me he replaced the alternator, put a I4 model on to save $10 and it just crapped out.
check the alternator and all the cables..
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
J
Altenator wiring issue?
  • JamesT23
  • Sep 24, 2024
2005 - 2014 S-197 Mustang -General/Talk- Sep 25, 2024
89ripper
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
