Alternatives to dccontrol e fan controller
  • Thread starter Thread starter svtpower
  • Start date Start date Feb 19, 2008
  • 3
1 of 3 Next Last
svtpower
257
Wisconsin
Feb 19, 2008
  • Feb 19, 2008
I am looking into doing a 3G alternator upgrade as well as a taurus fan and I keep reading that "dccontrol.com is the place to get them.
Well....looks like they don't have much of a site anymore. Anyone know where to get these or a good alternative?
302RollinHard
Columbus, OH
Feb 19, 2008
  • Feb 19, 2008
do a search. There are many controllers. You may just contact the site admin (as this is the owner) and get a hold of him that way. I'd recommend the dcc controller. It is a stout piece and worth the wait. he shuts his site down and only takes orders from certain groups (stangnet, corral, etc) at certain times so as to decrease his backorder time. He'll take your order when the group is up, if you are a member (which you obviously are).
Nova
128
  • Feb 19, 2008
theres a thread in the general tech section of corral about this. the guys really cut back on the controllers.
you can get a temp or timer control at autozone for $15.
93GTosu
183
  • Feb 19, 2008
i think "baskin" is the username of the dccontrol owner on corral and here. search his name and you'll find out how to get into the site. I believe you need a certain post count or been a member for a certain time frame at either site.
there are other option out there for fan control, but after reading on most of them...the dc unit seemed to be the easiest and better way of doing things for me.
5.0CRAZY
376
Frozen North
Feb 19, 2008
  • Feb 19, 2008
I have a taurus fan I was going to install soon as well. How much is the DC controller that baskin sells and does it come with the wiring needed as well? All I have is the fan itself so far.
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Feb 19, 2008
  • Feb 19, 2008
Just run a toggle switch to the fan. Turn the fan on when you're stopped, going slow, or on crazy hot days.
/thread.
goodfastncheap
100
Bellevue, NE
Feb 19, 2008
  • Feb 19, 2008
/thread.
...that's what I do on both my cars, but look at my handle.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Feb 19, 2008
  • Feb 19, 2008
I use the probe style adjustable controller that has the probe that slips under the radiator hose and has a knob you can adjust for what temp it turns on at. I keep it all the way down though. Works well enough and was like $30.
bynummustang
Jul 24, 2005
NC State University
Feb 19, 2008
  • Feb 19, 2008
Nothing wrong with that.
HISSIN50
34
129
Feb 19, 2008
#10
  • Feb 19, 2008
  • #10
If someone is considering a Delta controller, a toggle switch is not an option. It's like saying that one wants a Ferrari and someone saying to get a Pinto instead.
Here are the ordering instructions that were mentioned above.
FWIW, your opening post reads like DC Control is the place to get Taurus fans. YOu can get those fans anywhere. The controller (which can be used for about any fan) is what you have to get from Dc Control.
Good luck.
D
Deleted member 87397
Feb 20, 2008
#11
  • Feb 20, 2008
  • #11
Yeah it's Baskin. I sent hom a PM the other day cuz I wanted to order a controller and he sent a link back to me for the catalog on his sight so I could order. You have to have been a memeber for a while and have a decent post count for him to send you the link cuz I think he's had a lot of tire kickers in the past that have caused hi, trouble.
svtpower
257
Wisconsin
Feb 20, 2008
#12
  • Feb 20, 2008
  • #12
thanks
Thanks a lot for the replies guys!
I see them on that catalog page now...
One last question though.
Which one do I need? There is a lot of different controllers to choose from.
monte87
876
18
49
new york
Feb 20, 2008
#13
  • Feb 20, 2008
  • #13
A cheaper and easier way is simply get yourself a FMS 3/8 threaded insert T-stat housing, and a Painless Thermal switch 200on/185 off. With a 180 Mr. gasket T-stat and wire it upto the E-Fan to Ground, Be done with it. Unless you want all that fancy DC controller stuff, More of a headache when it breaks. But thats my opinion. I have had that set up in my stang for 5 years without any problems. Never had to change the thermal switch either.
if you need wiring directions, hit me back, They are just way to long to write out here.
Later Ant
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Feb 20, 2008
#14
  • Feb 20, 2008
  • #14
Later Ant
That was what i wanted to do originally but i found that the adjustable controller i got was even cheaper and it's pretty much a set it and forget it deal as well. Plus i have the option of turning it all the way down allowing it to get warmer in the winter.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 20, 2008
#15
  • Feb 20, 2008
  • #15
Using an electric fan without a controller or relay is asking for trouble. The simple on/off switches and thermo switches are not rated to carry the 30 + amps the fans pull. Top that off with the fact that most of these installations are wired with 12-16 gauge wire and you have an electrical fire waiting to happen.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Feb 20, 2008
#16
  • Feb 20, 2008
  • #16
Yeah mine is ran through a 35amp relay along with the controller. I'm going to be upgrading to an 80amp for my Mark VIII fan.
J
Jmunk
95
#17
  • Feb 20, 2008
  • #17
I read about SPAL, being a good company. They are on eBay for $69 I think.
Fett
766
#18
  • Feb 20, 2008
  • #18
I used a VW (80s Jetta) switch on mine, run through a 70amp relay and a large 40 amp fuse.
With the Taurus fan, I recommend wiring it up to the low side of the fan. I originally had it wired to the high side, but it was such a nasty start up, and really overkill for simple cooling purposes. I live in South Florida, and the low side on a stock rad keeps my car as cool as it needs to be. Another thing I noticed, it really seems like the low side of the fan has a slow start, where as the high side just KICKS on. Either way, I am very happy using the low side for cooling, and I am in the process of using a series of relays to hook up the high side of the fan to my AC, so basically it will work as it was supposed to. Low side for keeping the car cool, high side for blowing more air over the AC condenser.
svtpower
257
Wisconsin
Feb 21, 2008
#19
  • Feb 21, 2008
  • #19
Thanks
DCC 35 on order via the top secret order page!
monte87
876
18
49
new york
Feb 22, 2008
#20
  • Feb 22, 2008
  • #20
I do have a 75 amp BOSCH relay along with a 100 amp circuit breaker. The thermal switch is hooked upto Ground and my wiring is 8 guage. i forgot to mention that in my reply. I know at least about 4 toher guys who have the same set up-Trouble free for years.
Later Ant
  • 3
1 of 3 Next Last
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
