I am having a problem with my alternator. Cold starts are superb. If I drive the car around for an hour or more, turn the motor off, then try to restart, it hesitates and slowly cranks over. It only does this when I drive it a long time.
The ignition switch is good. The spark plugs, distributor, wires, ignition coil are all good. I've been told my alternator is faltering. If I run the AC full blast and use the power windows, the voltage drops near the bottom and the engine runs a little rough. Would a higher performance alternator with higher voltage do the trick? I think it is a stock 30K alternator.
I am also having trouble with my front end. When I drive the car for a while, I let the clutch out and do the normal driving. I can feel and hear a popping noise coming from around the wheel area in the front end. Bad struts or CV joints? It only does this when the car's been running a while.
If anyone wants pictures of my stang, let me know. It is a 1990 LX hatchback 5.0.
