Alternator problem ?
  • Thread starter Thread starter Hink
  • Start date Start date Jun 5, 2006
Hink
67
  • Jun 5, 2006
My Ampres Idiot light in my dash has been lighting up a lots lately . So I checked DC reading of battery with car running, it's at 15Volts. Someone told me this is a bad voltage regulator in my alternator . Is this correct or could it be a wiring problem ? Anyways I ordered one of those black HO alternators from Jeg's. Hope it will fix my problem with voltage, btw will this 15 volts possibly fry any of my car's electronics or sensors ?
TIA
Hink
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 5, 2006
  • Jun 5, 2006
did you try a different battery or do a load test on the one in your car..could be a bad cell
bill302
2,131
alabama,gadsden
Jun 5, 2006
  • Jun 5, 2006
i would think it was a bad voltage regulator or battery if the battery light is illuminating voltage reading should be 14.1-14.7 but you can find out free just take it to the local autoparts store and have them check your charging system... charging system problems can do alot of damage i would get it tested to know exactally what was causing battery light to illuminate...
Hink
67
  • Jun 5, 2006
Ok, will take battery out of car,to have it tested tomorrow. This would eliminate one possibility it sounds like.
bill302
2,131
alabama,gadsden
Jun 5, 2006
  • Jun 5, 2006
can you drive the car if so drive it to the auto parts store and they can test the whole charging system and tell you if its the battery, alt. or voltage regulator
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jun 5, 2006
  • Jun 5, 2006
the VR went in my truck and the volt gauge would climb up high with the moror RPM's
Hink
67
  • Jun 6, 2006
Worryed about driving the car with the voltages high, plus at the moment would have to drive a lots of extra miles going to town. Main highway is closed because, the Coal mine is installing railroad tracks across the highway out here. Off to get the battery tested now.
Hink
67
  • Jun 6, 2006
Battery tested, ok.
battery tested as a 750Amp. Store guy said "It's getting the ... charged outta it. So just waiting on alternator to arrive now.
Hink
67
  • Jun 8, 2006
Problem solved by new alternator! Funny thing Autozone checked my old one several times and it always passed.
Must just not be making enough current for all my systems, no more Ampres Idiot light ever now ! Oh and the car accelerates much harder now also
bill302
2,131
alabama,gadsden
Jun 9, 2006
#10
  • Jun 9, 2006
  • #10
auesome.... what year model stang do you have
Hink
67
#11
  • Jun 10, 2006
  • #11
My Stang is a 1987. Oh also the voltage readings I mentioned earlier were wrong , the meter a inexpensive DVM was reading higher than the volts actually were .
G
2000 GT- Alternator not charging
  • grugug
  • Nov 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 12, 2026
squeak93
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
