alternator suggestions.. please help
coming4you
32
Toms river NJ
I have an 88 coupe... with extensive amounts of work..
Im looking for a 140 amp alternator that doesnt use a 1 wire hook up and retains the factory harness.. or doesnt require much wiring at all.. and charges very well..
what are you guys using..
thanks in advance
Here's websites with pictures of the 3G installation...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
Use these sites for information on the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. If the fuse blows in the 4 gauge wire, the two 10 gauge wires will be overloaded to the point of catching fire and burning up the wiring harness.
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
Electric fan = 3G alternator if you want long life & reliability from your car.
The electric fan saves some HP. The stock fan's parasitic drag runs from 7-12 HP depending on who you talk to. The electric fan uses about 1/2 HP of power from the electrical system.
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder @ $5.80 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
Pre-fab 4 gauge cables with lugs already on the ends are available in most auto parts stores. Look for the starter switch to starter cables.
A tip from 04sleeper for a clean easy install is to use this harness (the top one).
Good luck.
I need to get started on this project as well. If i buy that 3G harness, all I need are... Right?
7-10 FT 4G Wire
Ring Crimp terminals
Fuse/Fuse Holder
Junk Yard 3G?
I have a Mark VIII fan, thats next... 130 AMP good enough and Start up and Idle?
7-10 FT 4G Wire
Fuse/Fuse Holder
Junk Yard 3G?
I would order some proper sized heat shrink if you dont have any that large (I didnt).
Otherwise, you might need a few ancillary items like a nut/bolt or a means to tap a boss, and little stuff like that.
The mark VIII has some decent draw - a true 3G should work easy if you use a variable controller. I will note that if buying a 3G, I might get a slightly higher output unit (I went with a 160) - that will help with the fan too.
Good luck.
snoboardcore said:
i would also like to know about the 3g alternator upgrade and what is needed
I am not sure if you saw the links provided in Jrichker's post - those will give you a good idea of what is needed/involved.
Good luck.
The local mustang junkyard has a 95 3g alt. $25, how much did you pay for yours?
I just ordered the 3g harness,
Where is that ground from the intake to the firewall, or what does it look like? Is it insulated or that flat bare metal wire?
Should I get a 150, 175, or 200 fuse? I will be using 4G all around.
That is my question too. I have a 95 amp 3g with 10 gauge wire going from the alternator to the solonoid on fender. I have never had any trouble with it in 3.5 yrs, but I want to go ahead and increase that wire to 4 gauge and put in a fuse. What size fuse should I use with the 4 gauge wire and 95 amp alternator?
I dont pretend to have 1/100th of Jrichker-like electrical knowledge but I fuse for the weakest link. I would use a fuse rated for 10 AWG over that length (for now). Once the alternator is the weak link, I would probably use a 100 amp fuse.
FWIW, I use a 150 amp fuse for the 160 amp alt. I do recommend buying an extra fuse and putting it in your glove box - just in case something ever happens (a connections comes loose and shorts to ground, etc).
For Rustang, I would use a 125 or 150 amp fuse (for a 130 amp alt)
Good luck.
There aren't any. The only option, if you want to retain the factory harness and mounting is, to use a the 95amp upgrade they make from paperformance.
But considering it's not much of an improvement over stock it's not really worth it.
So.....you should go with the 120 or 130amp. But it WILL require a new power lead, grinding of the bracket, at the least. Ideally you should replace the other wires too.
Although with my 130amp, I have been running just a new power main only with success.
for the power and ground wires, you could take some measurements and go to your local auto parts store and check out the starter wires. They vary in length and have both ends as ring terminals. That's what I did for my block to fenderwell ground. You could easily do it for your alternator power wire too. I wrapped the extra length around my front sway bar (I'm pretty sure that's what it is) for my 4ga alt power wire and used a 140amp circuit breaker w/ my 140 amp Powermaster alt; no fuses for me - all I gotta do is flip the breaker switch and go:D I don't think the circuit breaker was very high either - maybe $20 if I remember right - I can check later if desired.
Bringing this one back up to get some clarification.
I have done all of the searches, read all of the threads, and read everyone's links (especially jrichker).
I have decided on a 130 amp 3G alt.
My understanding is that the wiring explained by the links jrichker posted is simple - but to save time (been way too busy and I need as much time as I can do install the alt, supercharger & all of the supporting items), I can just buy the wire upgrade from PA-Performance http://www.pa-performance.com/display.asp?sku=65, correct? That would be the only wiring change necessary?
To save on money, I could do a reman. unit from Autozone, etc...lifetime warranty, but I have heard people have to use those warranties a lot.
So further pricing research shows that buying one of these reman. units would be just as expensive, so screw that.
To just do it right, I could do the PA-Performance 130 amp 3G to start. If I go this route, who has the best deal on them? I have already spent tons for my upcoming supercharger install, so anything I can save on this alt. upgrade will be great.
Thanks.
I have a reman from Advance Discount Auto Parts and haven't had any problems. The trouble with PA Performance alternators is that if it does go bad, you have 2-3 day wait to get the replacement unit. With mine, worst case wait is 4 business hours or less if I am willing to do some local driving to pick one up from another Advance Discount Auto Parts store.
criticman said:
Alright. What about the wiring question? The PA-Performance wiring upgrade is the same as what your link writeups would produce, just a lot less effort/time on my part, correct?
The main wire & fuse takes the same amount of installation time for either a 3G or a PA Performance alternator.
For a 3G only install, it takes 15 minutes max, to strip one white wire, solder another piece on, heat shrink that and crimp a female fast on tab connector. It's that simple. When I got done, all the stock wiring was still in place, still had all the factory connectors on it. In an emergency, if a 3G was not available, I could go back to using the original 2G without changing anything.
