Anderson tool for PI cam swap?
The Anderson tool is like a wedge that goes down in beside the timing chain tensioner and keeps it from tightening the chain while you pull the cam gear off and install the gear on your new cam. Without the tool the tensioner will pull the chain too tight you wont be able to do your cam swap without pulling the timing cover off.
If plan on pulling the front of engine you dont need the Anderson tool it would be pointless.
