Another AOD question
  • Thread starter Thread starter The Shape
  • Start date Start date Feb 29, 2004
The Shape
2,224
East ARKANSAS Delta
Feb 29, 2004
  • Feb 29, 2004
Ok I have an '87 GT with the AOD. The reason I am asking in this forum is because it seems over in the 5.0 forum most of the auto guys are drag racers who swap out the AOD for a C4. Where as over here alot of you guys are doing the opposite. I like my AOD and it has never given me any problems. I am just wondering what process you guys use to adjust the throttle valve cable? I have never gotten a straight anwers on this. Some guys say you have to use a presure gauge some say you just fiddle with it till it shifts like you want it too. I do know that if you adjust it wrong or it is disconnected it can fry your AOD quickly. I need to change out the grommet and bracket where mine mounts on my car so I just wanted to know how you guys went about doing the adjustment. Thanks
bnickel
5,640
lubbock, texas
Mar 1, 2004
  • Mar 1, 2004
the best way is to use a guage, but you can get it close by adjusting it so that there is just a slight amount of slack where the cable attaches to the throttle body, and i mean slight amount of slack, less than 1/8", but even then i would take it to a tranny shop and have it adjusted correctly with a guage, or just call one and ask their advice
corpse
2,562
chicago area
Mar 1, 2004
  • Mar 1, 2004
I will be the other guy I didn't use a gauge at all.
This was (more or less) my process, which my trans builder told me about. And yes, I was scared too of frying stuff - but just be patient and all will work out..
First, I removed the pump shot cams from the carb and hooked up the linkage, this way I can ensure I have the full range of operation. With the throttle closed, I had a slight amount of pressure on the cable - I set this by pinching the cable and pulling just a little bit - enough where I felt some spring pressure, and set it.
(put pump shot cams back on)
Very imporant - before you try ANY test driving, you want to make sure all circuits get filled up with trans fluid.. After the car is running for awhile, put it in reverse, neutral, all the gear - leaving it in each gear for a minute - and repeat this process for the gears a few times.
If the gears feel like they are engaging the way they should (not stalling shifting into gear), then you should be ready for a limited test drive. Drive in reverse a bit, then put it in 1st and drive around some.. If all is still well, you graduated to 2nd gear.. Be nice and easy from 1st to 2nd and pay attention to the shift point - the shift point is based on CAR SPEED, not rpm when setting this. If it shifts at the right speed, all other gears should be just fine - if the shifting is too late or too soon - stop the car right there, and readjust it.
I just noticed a small conflict - nickel think 1/8" of slack - I have my setup to be preloaded about 1/4". I didn't do it to be different, but IN MY CASE, the shift points were at the right speed, so I went with it.
The Shape
2,224
East ARKANSAS Delta
Mar 1, 2004
  • Mar 1, 2004
Mine is adjusted pretty tight now. Actually it looks like it is adjusted as tight as it will go. It shifts fine and has been like that since I bought it almost 3 years ago. Shifts nice and firm. Just wanted to make sure when I replace the little crappy piece of plastic ford used to attatch it I get it back right.
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
