Another battery relocation question...
  • Thread starter Thread starter GreatWhite
  • Start date Start date Jun 30, 2006
GreatWhite
232
Fairfield, PA
Jun 30, 2006
  • Jun 30, 2006
I got my Taylor aluminum box today and it just seems so huge. My battery is alot smaller as a whole compared to this box. What brand do you guys have? Also, how and where did you mount them? I'm trying to figure out the best place to mount it because it came with such a short ground cable. Thanks for your help. Pics would rock.
GreatWhite
232
Fairfield, PA
Jun 30, 2006
  • Jun 30, 2006
any help?
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jun 30, 2006
  • Jun 30, 2006
I have the taylor box too. Doesn't seem too big to me?
GreatWhite
232
Fairfield, PA
Jun 30, 2006
  • Jun 30, 2006
OK, maybe it's just because I don't have my interior back together yet... just seemed kinda large. How did you run your ground?
GreatWhite
232
Fairfield, PA
Jun 30, 2006
  • Jun 30, 2006
And did you drop the tank for drilling the holes? Any fuel lines run directly underneath there?
mustangsally93
281
Omaha,NE
Jun 30, 2006
  • Jun 30, 2006
Give me 20 mins I'll go out and take some pics.. I asked the same thing here and really didn't get any help. I drilled a hole on the d/s of the trunk right next to the tire. Then just put a bolt in there. Then grounded from the body to the engine.. But I'll take some pics here right now..
mustangsally93
281
Omaha,NE
Jul 1, 2006
  • Jul 1, 2006
Ok here you go. I got the pics but it was dark out I hope it helps.
GreatWhite
232
Fairfield, PA
Jul 1, 2006
  • Jul 1, 2006
So you can ground it to the floorpan?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 1, 2006
  • Jul 1, 2006
You must not have done a search, cause I've about worn out this tech note posting it...
Rear mounted battery ground wiring. Follow this plan and you will have zero
ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot
on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the
rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean
shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to
the chassis ground where the battery was mounted up front. Use a 5/16” bolt
and bolt down the 4 gauge engine to chassis ground, make sure that it the metal
around the bolt is clean & shiny. This is the alternator power ground.
The computer has a dedicated power ground wire with a cylindrical quick connect
(about 2 ½”long by 1” diameter. It comes out of the wiring harness near the
ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground
in the same place as you bolted the alternator power ground. This is an
absolute don’t overlook it item for EFI cars
Picture courtesy timewarped1972
Crimp or even better, solder the lugs on the all the wire. The local auto stereo
shop will have them if the auto parts store doesn't. Use some heat shrink tubing
to cover the lugs and make things look nice.
For a battery cut off switch, see
http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225 is the switch
http://www.moroso.com/catalog/images/74102_inst.pdf
Use the super duty switch and the following tech note to wire it and you
will be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire.
The 10 gauge wire they recommend is even less adequate that
the stock Mustang wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/4" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug
there is a green wire. On the diagram it is #904, lt green/red wire that connects
to the alternator and dash light. It is the sense lead that turns the regulator on
when the ignition switch is in the run position. Cut the green wire and solder the
40' of green wire between the two pieces. Use some heat shrink to cover the
splices. See http://fordfuelinjection.com/?p=7 for some excellent
help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire.
Try to run the green wire inside the car and protect it from getting cut or
chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp
on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs.
Do not add the jumper between the 1/4" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green/red wire is the ignition on sense feed to the regulator. It supplies
power to the regulator when the ignition switch is in the run position. Turn
the Moroso switch to off, and the sense voltage goes away, the voltage
regulator shuts off and the alternator quits making power.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-90 wiring and lots more…
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Diagram courtesy of Tmoss and Stang&2birds.
GreatWhite
232
Fairfield, PA
Jul 1, 2006
#10
  • Jul 1, 2006
  • #10
yes, and i've seen that post a million times. i just want to see pics of how you've grounded it... where you drilled thru and how you bolted the wire down. That's all. I understand how to wire it up so there is no grounding problems, that's not what i'm wondering. I just have the short ground cable that was included with the taylor kit and wanna see if i can use that or have to buy another one.
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • dan50
  • Jul 18, 2026
dan50
