Another GT 40P Question
  • Thread starter Thread starter Realmongo
  • Start date Start date Jul 18, 2005
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Jul 18, 2005
  • Jul 18, 2005
I may have to pull my heads for a valve job soon. Will the GT 40P heads go on an all stock '84 GT and work with the stock 4V intake and exhaust manifolds?
Realmongo
2,466
86
99
Western Mass
Jul 19, 2005
  • Jul 19, 2005
Anyone?
ProjectJ
  • Jul 19, 2005
The intake should fit fine, but the spark plugs will likely not clear the manifolds. The GT40P has a very odd spark plug angle.
Realmongo
2,466
86
99
Western Mass
Jul 19, 2005
  • Jul 19, 2005
I wonder what the Explorers use to clear the plugs?
bcd
274
arab al
Jul 19, 2005
  • Jul 19, 2005
you can use several different headers. The P specific headers are expensive but I think mac LTs will fit. Dont try equal length shorts. Dont know about regular shortys
nosmatt
1,356
Bass Lake, Ca
Jul 19, 2005
  • Jul 19, 2005
WELL, you can always try.
IF you need new headers, stock mustang 87-93 tubular shorties supposedly fit just fine, and they can be had for free.
they will not just bolt up to the stock exhuast tho, unless you have changed that out for the 86 and later setup......be good to do it all if you can tho, get the double hump x member, the 87-93 h pipe (with converters if you gotta smog check) and any old cat back system for an 87-93 LX stang.
I did all this on my 82 RS capri many years ago (sans the gt40p heads of course )
good luck
Realmongo
2,466
86
99
Western Mass
Jul 20, 2005
  • Jul 20, 2005
I am starting to gather all the hardware to make the switch over to the '86 and later setup.
R
Racerjoey1
76
Birmingham, AL
Jul 20, 2005
  • Jul 20, 2005
The 87-93 stock tubular headers will not work. I rebuilt my engine with P heads and cannot drive it yet because I have to save up for the headers. The passenger side was perfect, but on the driver side two of the plug boots are pressed against the header.
Check Jegs or Summit for the headers you need. In Jegs they are listed as 5.0L and GT40P specific headers but in Summit they are just listed for 5.0L's. Check out the part numbers though they are identical. Both catalogs list them for $239.
Good luck,
Joey
maverick0716
3,924
Chilliwack, BC, Canada
Jul 20, 2005
  • Jul 20, 2005
That 84 4V intake will choke the heads big time. I wouldn't expect huge gains if you're going to keep that intake on there.
Realmongo
2,466
86
99
Western Mass
Jul 21, 2005
#10
  • Jul 21, 2005
  • #10
I had a feeling it would have very small runners. I have been thinking of converting the car over to a FI setup in the future. One set of headers that look like they may work are the Ford Racing Parts High-Flow shorties. If so, they are supposed to connect right into the stock dual exhaust system.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
SN95 Hello new to this app
  • James S
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Habu135
