Another rear end question
  • Thread starter Thread starter FallujahMedic
  • Start date Start date Nov 15, 2005
F
FallujahMedic
74
North Central Florida
Nov 15, 2005
  • Nov 15, 2005
How do I tell what kind of rear end I have (8", 8.8", or 9")? on a standard '69 fastback, 3 speed mt, 2.79:1 "conventional" gears. I've been looking over at http://www.currieenterprises.com/cestore/ProductsRE.aspx?id=2085 for rear disc brakes and cant figure out which I need. Thanks
5.0StangRacer
227
Damascus, Maryland
Nov 15, 2005
  • Nov 15, 2005
8" if im not mistaken, 8.8" was much newer and 9" didnt come stock on any mustang I dont think...but dont quote me on that
T
ttoney
195
Denver
Nov 15, 2005
  • Nov 15, 2005
Plenty of Mustangs did come with 9" rears stock. In 36 years your Mustang could also have a replacement. There should be a tag on the rear (well, if you are lucky, I was) and plug those codes in for us.
Also, there are some decent sites with decodes and identification info.
http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
This is one. I had another really good one but misplaced the link. You can put narrower ones in there and gain the ability to use more B.S. but then you would need to switch wheels.
rbohm
6,698
550
204
tucson,az
Nov 15, 2005
  • Nov 15, 2005
ok first you likely dont have an 8.8 rear as they were not built untill the early 80's. look at the pumpkin, if the edges are smooth, then you have an 8" rear. if they are bulged around the bolt holes then you have either a 9" or 9 3/8" rear. the 9" rear did come stock on some mustangs, usually mach 1's and boss cars, or big block cars.
now to tell the difference between the 9" and the 9 3/8" rears, if you can put a socket and ratchet on the lower bolt, you have the 9 3/8" rear end.
Edbert
3,548
32
109
Austin TX
Nov 15, 2005
  • Nov 15, 2005
65-66 only the K-codes had 9s.
67 and up the K, the Boss302 and all big blocks had them.
I'm pretty sure your car came with an 8, early 65-68 6-cylinder cars had 7s, not sure about 69+ though.
But it certainly could have been changed out in the 35+ years since it was born. From the rear 8s look pretty round and 9s are oval.
tos
896
68
59
Cincinnati Ohio
Nov 15, 2005
  • Nov 15, 2005
I would also rule out the 8.8. But if your tag is missing then the two ways to tell that I use are number one if you look at the back side of the diff housing a 9" will have a raised area for clearance og the ring gear. This raised area will run up and down and can be formed a ouple of ways. I have two 9" rears and they are different. One has a very pronounced "hump" but the other is really suttle because the housing is a little larger and beafier. The 8" will be smooth and may have dimples like some 9's do. BUT the best way for me is to look at the two bottom third member studs/nuts. The nine doesnt have clearance to get a socket and ratchet on them but an 8" does.
F
FallujahMedic
74
Nov 15, 2005
  • Nov 15, 2005
Does this help identify it?
F
FallujahMedic
74
Nov 15, 2005
  • Nov 15, 2005
anyone?
thehueypilot
1,084
Medina,Tennessee
Nov 15, 2005
  • Nov 15, 2005
That's an 8".
65up2d8
281
Memphis, TN
Nov 16, 2005
#10
  • Nov 16, 2005
  • #10
thehueypilot said:
That's an 8".
Dead on.
D
D.Hearne
11,730
south louisiana
Nov 16, 2005
#11
  • Nov 16, 2005
  • #11
2.79's? That's an 8" for sure. No doubt about it. 9" rears didn't have 2.79 ratios.Nine's came with even number ratios, except for the 3.89's ( 2.50, 2.75, 3.00, 3.25, 3.50, 3.70) And the 8.8 didn't appear till the late 70's or early 80's.
bnickel
5,640
lubbock, texas
Nov 16, 2005
#12
  • Nov 16, 2005
  • #12
yep that's definitely an 8" rear.
i just wanted to add that starting in 69 all mustangs with 351 or larger engines came with a 9" as well.
d.hearne, i have to disagree about the gear ratios being all even. i believe there was a 2.79 for the 9" but i could be wrong on that one. however my old versailes rear came with a 2.47 diff. i swapped it for a 3.70 before i sold it. and they also came with 3.89's as well
F
FallujahMedic
74
Nov 16, 2005
#13
  • Nov 16, 2005
  • #13
Thanks guys, now I can buy more parts!! The wife complains that all I do is buy parts, the spare bedroom looks like an auto parts store hehe.
Edbert
3,548
32
109
Austin TX
Nov 16, 2005
#14
  • Nov 16, 2005
  • #14
Buying parts is better than buying lap-dances right?
At least from her perspective I imagine
T
New Guy from Southeast Missouri
  • tcooke11
  • Jan 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 17, 2026
TomcatPC
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
8.8 rear end for '67 coupe, shortened - next steps
  • rubendenver
  • Dec 15, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 8, 2025
GOvert
G
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
