Another spindle question?
  • Thread starter Thread starter 69clark
  • Start date Start date Oct 31, 2007
69clark
731
Ravena, NY
Oct 31, 2007
  • Oct 31, 2007
What do you guys recomend using for a 5 lug swap. Either 94-95 spindles or the 96+ spindles and why? I know that the 96+ widen the track slightly, but I am wondering if this is perfered or if the 94-95 is the way to go.
Thanks
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 31, 2007
  • Oct 31, 2007
Depends on the car alot of Fox cars don't like the extra 3/8 of track the 96 up kit gives for tire clearance reasons
P
PJB
131
Rotterdam, NY
Oct 31, 2007
  • Oct 31, 2007
I used '94 v6 spindles and it seems like most people use the '94-'95 ones to keep the same track width.
Since most people use newer model Mustang wheels when doing a 5 lug swap its preferred to use those spindles instead of '96+ ones because of the offset.
If using aftermarket wheels you can use either spindle as long as you get the right backspacing.
69clark
731
Ravena, NY
Oct 31, 2007
  • Oct 31, 2007
Well, I guess I understand the wheel fittment issue, but I would probably do a custom wheel so I could order what ever offset I need. So besides the wheel fitment issue, are there any other advantages?
PUNISHER RACING
1,124
FORD CITY, PA.
Oct 31, 2007
  • Oct 31, 2007
The 96+ cars have better calipers
Georgie
455
Montreal, Canada
Nov 1, 2007
  • Nov 1, 2007
well a wider stance helps, especialy on a nose heavy car..
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 1, 2007
  • Nov 1, 2007
The Front Calipers did not Improve until 1999!
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 1, 2007
  • Nov 1, 2007
About a Year ago someone on the Corral put up the Blueprints for the Spindles, 94-95s will increase your Stock Track Width by about 5mm per side, the 96-04s will add "another" 8mm per side. If you have Bumpsteer Issues you can stick with 94-95s and use 91-93 Tie Rod Ends or a Bumpsteer Kit, the 96-04s seem to handle Bumpsteer slightly better. My personal choice is to stick with 94-95s.
SuperStang83
1,693
Boyertown, Pa
Nov 1, 2007
  • Nov 1, 2007
It is easier to use the 94-95 spindles if you are going with a common wheel, but if you are going custom you can get away with either.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Nov 1, 2007
#10
  • Nov 1, 2007
  • #10
8mm is about 5/16"....not 3/8". Take an 8mm socket out of your tool set and look at the gap....it isn't much at all. I am using them with my 81 notchback. Reason....I am using the 2001 rear end. That puts the wheels out 1-1/2" on each side outward. So I will take all I can get on the front. 8mm will be better than nothing. It won't hurt either way.
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 1, 2007
#11
  • Nov 1, 2007
  • #11
my bad 94 to 98 calipers the same (it all gets so confusing!!!!!!!!)
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 2, 2007
#12
  • Nov 2, 2007
  • #12
It is actually 13mm per side as the 94-95s Increase the Track Width by 5mm and then another 8mm with 96-04s, but since you are going with a 3" wider Rear Track you can use the extra up front.
SVT32VDOHC
3,501
28
119
Motor City
Nov 2, 2007
#13
  • Nov 2, 2007
  • #13
Oh great. How come I haven't heard this before?? I think I will still be OK. I will get the left side on Saturday and I will mount the wheels and hang the fenders and see where they are at. If it looks bad I will switch to the 94-95's. I have both, so we will see what happens. Thanks.........
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 3, 2007
#14
  • Nov 3, 2007
  • #14
Thats my bad as my Post was probably not clear enough, the 96-04s will be 13mm Wider than "Stock" per side. The 94-95s are 5mm Wider Per Side and the 96-04s are 8mm Wider than the 94-95s.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Nov 3, 2007
#15
  • Nov 3, 2007
  • #15
Corrent, the dimensions that they increase are not correct
BOTH will increase your track...94-95 about 5mm and 96+ about 13mm total over the fox spindle
the 96+ offers better geometry and bumpsteer prevention.
Performancewise 96+ > 94-95...but then there is the whole offset issue.
Aftermarket wheels usually negate this, but with Ford 8 and 9" wheels, 94-95 is preferred.
Why most people haven't heard this is because Mustang myths spread like wildfire.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
