another voltage question
  • Thread starter Thread starter tims 86
  • Start date Start date May 14, 2011
tims 86
187
pittsburgh,pa
May 14, 2011
  • May 14, 2011
i did the 130 amp pa performance alt and wire upgrade and also contour fan setup.. i have a up and down idle so i checked the voltage, with all things running at idle its 12.5-13.5.... at approx 1500rpm its steady 14.3 and the alt gets pretty hot.. is this normal? does this have anything to do with the idle surge? safe to leave it like this?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 14, 2011
  • May 14, 2011
Have you added the 4 gauge ground from the engine block to the common ground point on the inner fender yet? If not, do that before doing anything else.
Is this a singe wire alternator (1 big wire for alternator output) or does it use 1 big wire (alternator output) and the stock D shaped 3 wire plug?
Single wire alternators produce less voltage at idle than the stock 3 wire + altenator output wire.
You may want to have one of the auto parts stores bench test the alternator for you. It is free and can eliminate the alternator as being one of the problems.
tims 86
187
pittsburgh,pa
May 14, 2011
  • May 14, 2011
it has the plug and also the 4 wire, and yes i just added the ground but no differance.
J
jamesburk3
  • Dec 27, 2011
Did you ever solve this problem? Im running the same setup ,and my gauge lights and headlights dim at idle or on the road when i push a window switch down. It reads 14 volts at idle as well.
stdyhand
62
Missouri
Dec 27, 2011
  • Dec 27, 2011
I upgraded to the 3G and have the same problem when I hit a window button. I installed the 4 gauge ground from the engine block to the firewall and from the negative terminal to the body. I thought a high amp alternator could handle the draw at idle and keep the lights brighter than the old stock alternator. But so far it acts just the same.
Also I did have my alternator tested at Autozone and they said it passed fine. I'm thinking about getting it tested again though to find out exactly what the voltage output is under load.
J
jamesburk3
  • Dec 27, 2011
same here, Cleaned up my grounds , ran an extra ground also and still having the problem. Im pretty sure my my stock alt wasnt doing this.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 28, 2011
  • Dec 28, 2011
Are you running an alternator from a 94-95 Mustang or a single wire alternator?
whitey68
56
12
central illinois
Dec 29, 2011
  • Dec 29, 2011
HI,
Yes I do have 3g alternator fits same place for 89 mustang 5.0
1) I have remanufactured one wire or two wires
price is $115 include shipping and hanlding within USA
2) I have Brand new heavy duty alternator
one or two wires, price is $145 include shipping
Mounting you don't need to modify, and for plug
you need to cut the plug and hook up new plug
it comes with plug and instruction
in case if you need the two wires,
if it's one wire
just run 4 gauge wire from battery to the alternator
if you take my advise two wires is better than one wire
but it's up to you
this is from eagle auto electric, they sell on flebay. i think im going to order one his feed back is good, im going to ask him if there is any idle issues he knows of
whitey
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 29, 2011
  • Dec 29, 2011
whitey68 said:
HI,
if it's one wire
but it's up to you
whitey
Buy it from a remote vendor and if you ever have problems, you have to take it off and send it back. Your car is down, you will have to pay shipping at least one way, and it's a headache to manage.
Buy the alternator from a local auto parts store with a lifetime warranty. If it breaks, you can take it back and get a new one, and test the new unit right there while you wait. When you walk out the door, you know it works correctly.
Two wire alternators work better at lower speeds than one wire alternators.
The mount modification is 10 minutes worth of work wit a dremel or a cutter bit in a drill. Don't be afraid of doing it.
Stangnet 3G install sticky http://www.stangnet.com/mustang-forums/646825-3g-alternator-install-how.html#post6673702 everything you need to know about 3G wiring.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
