Anti freeze on my floorboards????
  • Thread starter Thread starter saveferris
  • Start date Start date Apr 18, 2004
saveferris
21
  • Apr 18, 2004
I know I have read about this issue with Mustangs before, but I thought I would put the question out to everyone to get a answer rather than dig through all my mags. I have anti-freeze dripping into my passenger side front. What causes this, what's the fix, is it a "easier" do it yourself. Or is it more involved work. Any advice would be greatly appreciated. Thank you in advance.
Hack
1,945
Minneapolis
Apr 18, 2004
  • Apr 18, 2004
Sounds like your heater core is leaking. I haven't done the repair on an early Mustang, but it's not that difficult.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 18, 2004
  • Apr 18, 2004
Could be the heater core, OR one of the hoses leaking where it attaches to the core.
L
littlered1
  • Apr 18, 2004
Most likely your heater core is busted. Check for any loose hoses before you spring for a new one. I had this happen to me. It was one of the first things that i replaced. Since it is summer, and heat isnt as desireable, you can always bypass the heater core and not worry about it. Worked for me until it got cold last year.
MitchStang68
10
So. California
Apr 18, 2004
  • Apr 18, 2004
This happened to me not to long ago, i just rerouted the hoses for now, i'll fix it when it's cold and i need a heater. good luck
70stangcoupe
2,895
Winston-Salem, NC
Apr 18, 2004
  • Apr 18, 2004
I'd say your heater core crapped out on you. It is also possible that a hose connecting to the heater core is leaking though. You'll just have to crawl under there and see!
TobyGaff
211
Indianapolis
Apr 18, 2004
  • Apr 18, 2004
I had the same problem. I thought that it was my heater core, but upon tearing it apart I found that it was just a cracked hose. My recommendation is that whatever you find, replace the heater core anyway while you have it apart. They are only $20 and it will save you a lot of time later.
O
Ozsum67
Too much thin air
5,152
Eastern Colorado
Apr 18, 2004
  • Apr 18, 2004
Well I'm glad we're all in agreement. Anyone else want to AGREE?
87gn2
101
  • Apr 18, 2004
I'll agree!
saveferris
21
#10
  • Apr 18, 2004
  • #10
Thanks for the info everyone. I'm in Wisconsin and it's a 69 convertible, so I use the heater during the short season we do get. I appreciate the quick reply. Any other info is welcome. Just wanted to say thank you.
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
