Are you asking about anti-seize or Loctite?Ok. The reason I ask is because when I took off the the lower the passenger side bolts were like finger tight
Ok so no to loctite but possibly yes to anti seize?Are you asking about anti-seize or Loctite?
If you are thinking about a thread locker, like Loctite, then no, you don't use that on intake bolts.
Yeah, the good thing about anti-seize is that it is formulated to stop the chemical corrosion created by combining stee/iron with aluminum, and unlike oil, it will be there forever, until you take it back apart.I always used a little oil. Maybe next time ill use anti-seize
