I'm restoring a '69 fastback and while it's driveable, i'd like a bit more peace of mind knowing I'd taken some antitheft measures as I don't have a garage to store it in. Outside of a couple of kill switches wired into the distributor circuit, I'm thinking of putting a fuel line cutoff near the tank, valve handle extending through the floor pan under the back seat. Years ago in Houston, i recall seeing a similar valve that installed in the floor pan only using a key to rotate the valve stem to the off/on position desired. Can't find one now but you get the idea. Hood locks are easy to spot once inside so I figured disabling the car would be the best bet.
And what's a good, basic alarm setup? Most now rely on some of the electronic systems inherent in today's models, and thus, are probably not suitable. I cobbled one together while in Houston for my '65 using a lockswitch, relay and flasher module to sound the horn but it will continue to 'blare' off/on until the thing is reset. Your suggestions, please!
Michael
Michael
