Antifreeze ???
  • Thread starter Thread starter marine_2003
  • Start date Start date Jul 21, 2005
marine_2003
427
Lake County, FL
Jul 21, 2005
  • Jul 21, 2005
How should I run my antifreeze? I am hearing different things from different people, all antifreeze top off with water, 50/50 antifreeze. What should i do? -stat, no t-stat??
Please Help
Thanks
ss93cobra
1,422
Wilmington NC
Jul 21, 2005
  • Jul 21, 2005
50/50, run a t-stat, and dump in a bottle of water wetter for good measure.
marine_2003
427
Lake County, FL
Jul 21, 2005
  • Jul 21, 2005
What degree t-stat?
sunil6784
620
Boston, MA
Jul 21, 2005
  • Jul 21, 2005
I use the stock 192 w/o any problems, but most people use a 180 so the computer richens the mixture a tad. Don't run a 160 though, thats too cold. it'll richen the mixture too much, and cause problems w/ u're cats and stuff.
marine_2003
427
Lake County, FL
Jul 21, 2005
  • Jul 21, 2005
My car is carburated and i have no cats no emission stuff.
1989MustangLX
118
Canada
Jul 21, 2005
  • Jul 21, 2005
It is still better to run a 180 thermostat at least. I've heard that you shouldn't use water wetter and antifreeze together, and that it is designed to be used purely with water. I have no personal experience there, but I read it on here or the Corral. I run 70/30 water/antifreeze.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 21, 2005
  • Jul 21, 2005
In the summer, run mostly water, like 1989MustangLX suggest 70/30 water/coolant.
HISSIN50
34
129
Jul 21, 2005
  • Jul 21, 2005
Yep, what I would do:
Run the least amount of coolant needed to take care of the lowest winter temps you will see.
Use distilled water for the rest.
Run a bottle of cooling system lubricant and rust inhibitors.
Run a wetting agent (I would use two bottles).
More water than coolant is better for thermal rejection - water transfers heat 2.6 times better than coolant (coolant is 'heavy').
As said, DO run the t-stat. If you insist on running none, at least run a restrictor plate.
Good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jul 22, 2005
  • Jul 22, 2005
Good luck.
If you did not say it I was going to about Distilled water, tap water is no good for your vehicles!
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
V
Engine Antifreeze in oil
  • vinzo
  • Oct 9, 2024
Fox 5.0 Mustang Tech Oct 10, 2024
vinzo
V
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
D
1996 gt mustang block temp vs coolant temp
  • Dkuehn
  • May 21, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2026
squeak93
87 fox code 22
  • Showpony87
  • Aug 9, 2024
Fox 5.0 Mustang Tech Aug 10, 2024
Showpony87
