Any advice before hitting the Dyno?
  • Thread starter Thread starter Clark
  • Start date Start date Sep 28, 2005
C
Clark
659
Rowlett,Texas
Sep 28, 2005
  • Sep 28, 2005
Hello to All,
Finally getting around to putting the 393W on the dyno and this is one of those $25 for three pulls and no tuning and I thought it would be good to find out where I sit on horsepower. But after talking with the guy running the shop he told me that I could be pulled after the first run if it is to lean or rich and obvious things like leaks. This made me wonder if there is anything you guys would recommend to help this go smooth, Thanks.
G
gzminiz
200
Phoenix, AZ
Sep 28, 2005
  • Sep 28, 2005
How much extra is the tunning? Might be worth it, first off, you get it tuned properly, second you are guaranteed all three pulls as they should be fixing if it is lean or rich.
iskwezm
4,159
20
79
Rowland Heights,California
Sep 28, 2005
  • Sep 28, 2005
tighten all your hoses,check for vac. leaks,fule,coolant leaks.Ive seen a few cars blow radiator hoses off on the dyno.
thehueypilot
1,084
Medina,Tennessee
Sep 28, 2005
  • Sep 28, 2005
I have had my car on the chassis dyno twice so far. (roller drum and direct drive) The $25 for three pulls does not include hooking anything up. (To get an accurate A/F reading you will need a bung welded into your exhaust system before hand.) The first pull gets your rpm matched to the computer and the second pull confirms the rpm is correct and the last pull will be your print out to show your buddies. If your car is not dialed in and has any problems you will be dissappointed. If you want them to tune your car for max performance, well......that will cost you extra. A tuning session will run about $100 per hour (avg.) and you will have to provide the labor and tools. The last pull will let you know if your cooling system is good. Good Luck!
C
Clark
659
Rowlett,Texas
Sep 30, 2005
  • Sep 30, 2005
Thanks Huey, for the advice and for helping me with my memory loss
From what you said should I just not go for these pulls unless I have it dialed in first?
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Sep 30, 2005
  • Sep 30, 2005
Last time I went to a dyno day they just put a probe in the tailpipe to measure AF ratio. Well.. on the cars without catalytic converters at least.
If you use a heated O2 sensor, you can measure AF ratio at any part of the exhaust system so long as it's not after a catalytic converter.
10secgoal
2,801
San Diego
Sep 30, 2005
  • Sep 30, 2005
Advice for hitting the dyno
Do not go with a stock drive shaft.
iskwezm
4,159
20
79
Sep 30, 2005
  • Sep 30, 2005
why?
Dark Knight
2,578
Chandler, Az.
Sep 30, 2005
  • Sep 30, 2005
why not just pay for 2 sets of pulls? do the 1st set to get a baseline, then tweak the car some and go again later
I've made a few pulls on my vert and never had a prob
thehueypilot
1,084
Medina,Tennessee
Sep 30, 2005
#10
  • Sep 30, 2005
  • #10
It's a nerve racking experience to stand beside your car when it is making a 6k pull.
10secgoal
2,801
San Diego
Oct 2, 2005
#11
  • Oct 2, 2005
  • #11
iskwezm said:
why?
It's only good for about 473 ft/lbs to the ground. Then it gets angry.
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
