  • 1994 - 1995 Specific Tech
any kinda temporary fix?
  • Thread starter Thread starter 5literstang
  • Start date Start date May 30, 2004
5literstang
1,374
Clark, NJ
May 30, 2004
  • May 30, 2004
well i have blowby and i ordered a DSS 306 Shortblock, but i won't be in for at elat 2 weeks then off to the shop so i'll proly have my car back at the end of june, well my car smokes badly and purs threw the vents, is there any kind of temporary fix i can do til my car goes in the shop? anyway i can make it stop smoking for a few hundred miles so i can at least drive it? thanks
cjones
1,561
Avondale, AZ
May 31, 2004
  • May 31, 2004
normally you'ld get coolant smoke through the vents. Does the smoke smell sweet or like oil.
if it's coolant you'll want to by pass the heater core or replace it(after you make sure that's what is leaking).
if it smells like oil: with the hood, engine running can you see where it's leaking. blow-by should be pulled back into the engine by way of the PCV system(check to make sure the valve is working). if you have really bad blow-by it may have blown out a gasket(valve cover or rear intake seal).
there's a product in a silver can, i think it's called Restore. i've had to use that before and it did ok.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 31, 2004
  • May 31, 2004
Run an open breather...you can get one that screws right into where your oil fill cap is. I like to run them on everything.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
