Any nice shift knobs?
Noits no a jet, but hopefully ine day. It was spposed to be all my nitrous equipment hooked up seperatly, now the only thing working is the line lock. I had a suspension problem at the track and had to put the nitrous on hold for now.
I love my UPR
I have the mgw "gt" knob... but I don't like it that much... it looks real nice... but it gets warm very quickly and then hot to where it hurts to touch it after an hour or so of driving... I wish someone made a nice leather or suede one...
RageStangX said:
warm from like heat outside, or from the car itself?
Both, but more from the tranny than from the sun (if you have tinted windows). I live in Western Kentucky (and spend a lot of time in East Texas), so it does get pretty hot. I noticed when I first put my Tri-ax on it got really warm, but a little electrical tape and a couple of cheap rubber washers on the base (where the handle mounts) and it has not been a problem since then.
I love T-Handle shift knobs! I called around for a hurst, or B&M handle ... and i had no luck whatsoever! Pep boys carrys all that ricey-neon-fast and furious crap, so i wouldn't even try to look there. I tried Summitt, Jegs ... they were out of stock! Luckily I found one at a local "mom and pop" auto parts store, so I custom fit the B&M T handle on my car, because all threaded I.D-O.D bushings that came with the handle wouldn't mate with the 12MM thread on the stang. I made a billet aluminum stop pc./ handle cover to avoid using hex nuts as stops. (I just copied design from the bottom part of a bullitt ball knob.) Looks and feels pretty awesome! I guess my being a cnc machinist helps matters, but if you have access to a machine shop ... you can do it very easily with just a manual lathe and a drill press. Most machinists are motorheads, so I'm sure you could get help by one if ya need it. If you can find a metric handle, more power to ya ... if you need help converting, just email me [email protected]. For all of you T-Handle freaks!
Note: Thread size is M12 X1.75.
I also have the Bullitt shift knob. I don't like knobs with grip to them because I prefer to move my hand around depending on what shift I'm doing.
2kyellowgt said:
I like mine nice and simple, UPR billet 5 speed. The button off to the side is my line lock.
I like that switch panel! Where did you get it/the parts for it from?
Thanks :nice:
I made it out of some aircraft switch covers, Toggle switches, lights, and a piece of aluminum that I polished. I am just trying to find a better way to mount so I can remove it a little easier to add more accessories.
