If so how good does it work and where is a cheap place to get one. I am wanting to jump up to 15-16 pound of boost because i just bought some VT cams and Comp Springs.
el_kid_1 said:I see you are from West Lafayette, IN? I'm a Purdue graduate! Let me know if you have any other question. It is always good to help a fellow Boilermaker![]()
GitDat said:Are you running that much boost on the stock block? I'm from Indianapolis. I pass through Boilermaker territory pretty often![]()
orangestang2000 said:If so how good does it work and where is a cheap place to get one. I am wanting to jump up to 15-16 pound of boost because i just bought some VT cams and Comp Springs.
white99gt said:Are the cams set up for boost?
Because ever combo is different.Do you have a power pipe?
Based on your boost pressure now you have about 15 psi(before the cooler).I see about 16 psi with a 3.1 pulley @ 7k.Whats your fuel setup?
THese are all major issues that need addressing when shooting for that power level.
I run a BAP with 03 cobra pumps.
orangestang2000 said:Yes these are the blower cams that you can see specs on a modulardepot.com, i have a 3.125 pulley and i currently do not have a power pipe. For fuel all i have right now is a 255 in the tank with 42 lb injectors.
When talking to scott @ vt he said i could see at least 50 horse from just the cams.![]()
word.el_kid_1 said:I'm a BAP user. It came with my supercharger kit. You can get yours directly from Kenne Bell. I would suggest you read this article: Boost-A-Pump Theory Explained for more information on the KB BAP. Good Luck!
