Anyone know how to fix the Map Light?
  • Thread starter Thread starter SuperStang83
  • Start date Start date Oct 7, 2007
SuperStang83
1,693
Boyertown, Pa
Oct 7, 2007
  • Oct 7, 2007
I took my Map Light apart last night to try and fix it, but I don't think that it comes apart at all. I am getting power to it and into the switch, but after that I lose power. Is there an easy fix for this or not?
Jacob
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
  • Oct 8, 2007
No ideas?
Aryan15
236
CA
Oct 8, 2007
  • Oct 8, 2007
You have to drill out the plastic rivets, pull the spring perch off, and put a spacer or different spring to close the switch. The spring loses its ability to close the switch. Then glue it back together. I've done two so far. Good luck.
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
  • Oct 8, 2007
Awesome, I'm gonna give that a shot. Thank you man. Any kind of special glue?
Aryan15
236
CA
Oct 8, 2007
  • Oct 8, 2007
I used JB Weld.
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
  • Oct 8, 2007
Alright, awesome I'm sure it'll do the trick! Appreciate it man!
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
  • Oct 8, 2007
I took it apart and there doesn't seem to be anything wrong with the spring at all, but I'm gonna try and put a small spacer in there. Did you just use something like a washer?
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
  • Oct 8, 2007
Sweet, got it working man!
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
  • Oct 8, 2007
Haha, awesome tip Aryan15! I just fixed a buddies too!
stang&2Birds
2,091
New England. :-) CT/MA
Oct 8, 2007
#10
  • Oct 8, 2007
  • #10
I don't believe you. I'll send you mine to see if you can really fix it.
Was it as simple as it sounded? I'd love to have my map light working again also.
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
#11
  • Oct 8, 2007
  • #11
Stang it was super simple. I didn't believe it myself. I just drilled the switch apart like Aryan said and put something in there to help the spring get more pressure on the contact points. Funny thing is I actually cut a small piece off a popsicle stick and put it in there for my buddies car and it works perfect now. I put it all back together and just epoxied it so that it would stay. No one will ever see what it looks like on the inside anyway.
SuperStang83
1,693
Boyertown, Pa
Oct 8, 2007
#12
  • Oct 8, 2007
  • #12
Actually if you want you can send it to me. I'll have that thing fixed in 5 minutes, that's including the 3 minutes for the epoxy to harden. That's how easy it really is.
stang&2Birds
2,091
Oct 8, 2007
#13
  • Oct 8, 2007
  • #13
Cool. Thanks!
I'll try it!
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
