Anyone running World Windsor heads? on a 351w??
streetgrande69
976
Splendora, Tx
I was wonder if any of you guys...or girls have the mentioned heads above? I can't figure out how to mount the spacer brackets required for my alternator or my power steering pump on my '69 351w. Any suggestions or pictures would be great!
hey E, got any pics of the problem? i have always assumed they mounted like normal with the same bolt patterns, etc. although i do seem to remember something about reducer bushings for the bolt threads
http://www.worldcastings.com/tech/WindsorJrTech.pdf
interestingly enough, i bought these heads used so i didn't have the instruction sheet that goes with them. well i found it (above) online and the piece was listed on it (bottom left under...accessories). 50 dollars later and calling a few area ford dealers got me the patt. it was a helicoil looking thing that went into the hole. it was right on the money....50 bucks for these 2 little plugs! but you gotta do what you gotta do, ya know.
i feel kinda dumb but if i had the sheet in the first place it wouldn't of been a problem.
here is a pic of the 2 heads and the holes....bottom head, top hole is the problem. its the reactor hole on newer fords, needs to be pluged in my thing.
