Anyone Seen this before?
Wayne Due is building frames for 1st gen Camaros. I have also seen this frame, and tried to get more info. Art Morrison also does some frames.
The basic idea was something I wanted to look into when I was first doing my convertible, figuring that a serious chassis would be a good starting point for a performance convertible. I wasn't thrilled with what I found [this was >2 yrs ago] for the cost, and thus we started cutting and welding.
The Ring Brothers had a custom frame [Art Morrison IIRC] for their 'vert.
brianj5600 said:
Care to share? Steering looks like there is not enough travel for the long looking steering arms on the spindles.
Well, to note a few problems;
The front swaybar looks like it may have ground clearence issues?
The upper A-arm heim joints are a little smaller then I would like, and the fact that every suspension point is solid would suck for a street car.
The worst thing I see is the upper and lower rear shock mounts are single sheer and stick way out. They look way weak.
The rear suspension is a satchel link four bar setup. If I was going to go to that much trouble to make a chassis like that I'd use a three link, or a properly designed parallel four link.
The rack and pinion input shaft looks like it would be a pain but other wise the nice long lower a-arms look good.
Good point about the spindle arms...guess its about on par with TCP stuff that everyone is gonzo about.
10secgoal said:
If it functions good, seems damn good to me. Basically a built rear, and MII front end, and full frame for only 3k ? Gonna spend that on the MII
It's not going anywhere near $3000!!! Notice the 'reserve not met'? That WOULD be a great price, no doubt. I'd look towards adapting it for an earlier model [likely do the TCP-type push-the-fender-sheetmetal-out trick].
Thanks for the tutoring! Helpful to read and then look at the pics.
kmterrill said:
A question. I thought the Satchel was better since it got rid of the Panhard bar?
That is the reason a Satchel is inferior, because it does not have a Panhard or Watts. With the additional lateral link you can adjust the rear roll center.
It could be argued that a Satchel link suspension could be made to do the same, but a Panhard would allow more adjustment and be easier.
But by adding a watts or panhard bar you're just adding weight to the car? How much adjustment do you need on a properly designed suspension?
