  • 2005 - 2009 Specific Tech
Anyone using a PCV oil separator system?
  • Thread starter Thread starter mpentico
  • Start date Start date Nov 2, 2006
mpentico
181
  • Nov 2, 2006
I removed my throttle body assembly last week to make some measurements for a home built throttle body spacer.
(Not that difficult) I'm making it out of Delrin plastic for ease, heat resistance and light weight.
I found quite a bit of oily residue in the throttle body throat and beyond.
Some wet, some dry.
Much more than I expected to find at 40,000 miles.
The car does suffer from detonation, so my idea is to install an oil seperator on the PCV system.
Anyone already got one installed?
What brand?
What style? (bell jar, paper filter, or motoblue?)
Does it work well?
Any info would help.
N
nbk13nw
186
Newport News, Va
Nov 2, 2006
  • Nov 2, 2006
There are many prople using separators. A lot of threads out there on many different forums.
I took some pictures of the CMCV plates when I installed the FRPP delete plates last month. There was quite a bit of blow by after 46K miles.
JTGrant
775
GA
Nov 2, 2006
  • Nov 2, 2006
i had a good amount of oil in my intake manifold.
anthony05gt
1,262
Maryland
Nov 3, 2006
  • Nov 3, 2006
All you have to do is buy the oil separator kit from Steeda or someone else, cut the pcv hose and put the separator between the 2 cut sections of hose. Of course you'll have to drill and mount the bracket that comes in the kit.
If you are experiencing detonation right now you should get that tune tweeked.
metroplex
405
SE MI
Nov 3, 2006
  • Nov 3, 2006
FWIW I don't see how the oil separator kits are of any benefit unless you are running a roots or twin screw supercharger with the intercooler that can get clogged with oil from the blowby residue/gases.
If Ford felt it was going to be a problem for the engine out to 150,000 miles, they would have installed an oil separator. I'm surprised they did NOT install oil separators on the 03-04 Cobra, Ford GT, GT500 and Ford Lightning with the blowers.
I have heard from tuners in the past that the PCV's blowby gases can reduce "horsepower" due to the hot oil getting burned in the intake air mixture but I have a 1981 302 V8 that has had about 25 years worth of blow-by residue in the combustion chamber and heads. It does not detonate on 87 octane gas.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Nov 3, 2006
  • Nov 3, 2006
anytime you can reduce oil in the combustion chamber/intake tracts, it is a good thing, IMO.
metroplex
405
SE MI
Nov 3, 2006
  • Nov 3, 2006
I agree, but how much of a gain do you really see? A restriction in the separator will probably cause more problems than good (restricted PCV system can cause ring sealing issues).
anthony05gt
1,262
Maryland
Nov 4, 2006
  • Nov 4, 2006
I think it's more about keeping a build up of deposits out of the intake tract than anything and definitely out of the intercooler in my case. Bottom line is if you see oil deposits an oil separator will only improve that.
JTGrant
775
GA
Nov 4, 2006
  • Nov 4, 2006
Agreed.
mpentico
181
#10
  • Nov 7, 2006
  • #10
Well it took some time and more than a few trips to the parts store, but I now have an oil seperator for the PCV system.
I replaced the driver side PCV valve cover vent line with a mini K&N style filter directly off the cover and plugged the intake vacuum port.
(Not emission legal)
Then installed the oil separator filter/bowl inline with the passenger side valve cover PCV vent line.
So far I have not had any drivability issues, keeping my ears open for detonation, and watching my milage.
Hopefully this will solve the problem.
bigcat
May 1, 2005
3,015
7200 feet
Feb 17, 2007
#11
  • Feb 17, 2007
  • #11
any updates? hows it holding up?
R
Fox Closed PCV System, Dual Valve Catch Can
  • RTW0223
  • Dec 6, 2019
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 30, 2021
jay98
SOLD For Sale 92 Mustang Notchback Complete Rebuild in 2019
  • pearlnotchback
  • Jun 21, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 24, 2021
Steel1
Install Daytona Sensors CD-1 Ignition Mustang Fox SN95
  • revhead347
  • Sep 21, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
AeroCoupe
M
I really wasn't expecting this....... First time Mustang owner.......
  • Mikedd969
  • Nov 27, 2019
3K
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2019
Mikedd969
M
For Sale 1994 GT 5L Trickflow h/c/i Tremec TR3550 Saleen copy - $7000 (Ann Arbor, MI)
  • no_fox_given
  • Mar 21, 2019
9K
SN95 Mustangs For Sale (1994-04) Mar 21, 2019
no_fox_given
