  • SN95 4.6L Mustang Tech
Anyone Using Comp 270's??
  • Thread starter Thread starter cltgt
  • Start date Start date Apr 10, 2004
C
cltgt
931
Geneva, Fl.
Apr 10, 2004
  • Apr 10, 2004
Just wondering if anyone is using these cams and what the drivability is with them?
C
cltgt
931
Geneva, Fl.
Jul 12, 2004
  • Jul 12, 2004
nobody has any feedback?????
A
AmerMuscleGT
31
Connecticut
Jul 12, 2004
  • Jul 12, 2004
Well I remember that MM+FF used the XE274 (or something close to that) grind in their 2V engine, and it was a fantastic addition. Added 105 hp to the blown motor, and something like 40 hp to the N/A version. So Im guessing that one is pretty good too. Just be sure to have a good install done, a couple people have noted valvetrain noise, but this wont happen if it's done right.
C
cltgt
931
Geneva, Fl.
Jul 12, 2004
  • Jul 12, 2004
I'm having it professionally done, don't have time to waste by not doing it right.
nickthegenius
1,631
Elwood, IN
Jul 12, 2004
  • Jul 12, 2004
I have the XE270AH cams. You definitely need a tune as mine would die at stoplights and didn't want to idle very well. With the tune, its just like driving a stock car, but you have a nice lopey idle.
C
cltgt
931
Geneva, Fl.
Jul 12, 2004
  • Jul 12, 2004
does it idle pretty rough?
nickthegenius
1,631
Elwood, IN
Jul 12, 2004
  • Jul 12, 2004
It won't shake your fillings out of your teeth at a stoplight, but its definitely lopey and any gearhead within hearing distance will know its cammed. My tuner set my car to idle a 850RPM. I suppose if it idled closer to the stock idle number, it would be pretty rough.
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Jul 12, 2004
  • Jul 12, 2004
I got em too. they have a pretty choppy idle but you can raise the idle to smooth it out if you want. Drivability is pretty good I think, but there is a lot more power like 4k on up. I agree with clgt that you will have to have a tune.
9
98SteedaStang
382
Chicago Suburbs
Jul 17, 2004
  • Jul 17, 2004
What do you need to go with a 270 grind cam. You can still run the stock PI intake right? Would I have issuse cause of my auto trans?
C
cltgt
931
Geneva, Fl.
Jul 17, 2004
#10
  • Jul 17, 2004
  • #10
your PI intake will work, but you will probably want to get a torque converter and a tune.
9
98SteedaStang
382
Chicago Suburbs
Jul 18, 2004
#11
  • Jul 18, 2004
  • #11
Perfect I wanted to get a converter anyways. The 270 grind is the middle stage right?
C
cltgt
931
Geneva, Fl.
Jul 18, 2004
#12
  • Jul 18, 2004
  • #12
yep.
nyuk98gt
1,427
Chesterfield, MO
Jul 18, 2004
#13
  • Jul 18, 2004
  • #13
Aren't new springs needed for the 270s? The valves are opened for a longer time period and at very high rpm, there is a lot of strain on the [stock] springs. For information, the 262's are the 'street' - you can use stock springs, the 268s are the 'mild street', and then there are the 270's and 274's. The power gains increase in the series but the power is produced higher up in the powerband as you go up the series.
You don't want to do the cam install twice so call Comp Cams for their recommendations for springs and cams for your application. Their techs are there to help out and the help is free (well, it's built into the price of the cams but you know what I mean).
9
98SteedaStang
382
Chicago Suburbs
Jul 19, 2004
#14
  • Jul 19, 2004
  • #14
Yeah I think you need new springs with the 270's. Comp makes them they are like $190
9
98SteedaStang
382
Chicago Suburbs
Jul 19, 2004
#15
  • Jul 19, 2004
  • #15
nyuk98gt, how do you like your cams? Also how do you like your Jmod? You have similar mods to me any Idea of what numbers or times you are making? I have a lowly 213hp and 260tq. I'm looking to do some cams, LTs, and an off road mid pipe not sure if I want to stick with an X or switch too an H pipe.
Indiana
286
#16
  • Jul 19, 2004
  • #16
Nick,
A) Where do you get a tune in Indiana?
2) What did they change besides the idle for your cam-swap?
nickthegenius
1,631
Elwood, IN
Jul 19, 2004
#17
  • Jul 19, 2004
  • #17
Indiana said:
Nick,
Automotive Specialists in Noblesville. If you call, ask for Brent and he'll help you out.
http://www.auto-spec.com/dynojet.html
They had to play with the air/fuel tables in the EFI mapping because I had also added LTs, X-pipe, plenum, etc. right before the dyno. I took the car into the shop running a Steeda reflash. He said it wasn't that far off, but was too lean down low.
Indiana
286
#18
  • Jul 19, 2004
  • #18
Thanks!
paver1
330
HELL-The hottest part.
Jul 19, 2004
#19
  • Jul 19, 2004
  • #19
I am running the XE278AH Comp Cams in a '96 306 stroker with a supercharger. Definately a lopey idle but serious power in the 2500 - 6000 rpm range. Your stock springs are good to .550 lift which is what the 278 has..........
C
cltgt
931
Geneva, Fl.
Jul 23, 2004
#20
  • Jul 23, 2004
  • #20
Are 270's too much for a headswapped engine?
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
