Engine AOD 5.0 stalling
  • Thread starter Thread starter MarAteTheFood
  • Start date Start date Sep 9, 2023
M
MarAteTheFood
Da Bay
Sep 9, 2023
  • Sep 9, 2023
my 92 vert’s been sitting for a couple weeks
some days it’ll run for an hour (usually how long I wait before I get bored) but some days it’ll run for no less then 5 minutes without stalling out and dying.
I’ve already replaced the fuel pump and fuel pump relay and I regularly check the pressure so fuel isn’t the issue.
im assuming it’s the distributor but is there anything else I should look at?
hoping to resolve this soon because it’s been my daily lol
also please don’t chew me up this my first car that I’m learning on and also my first post on here
AeroCoupe
6,182
4,280
183
Claremore, OK
Sep 9, 2023
  • Sep 9, 2023
Have you checked for KOEO and/or KOER codes?
Reactions: Mustang5L5
slow84lx
clean it good before insertion
Jul 3, 2005
372
180
63
Dallas, TX
Sep 10, 2023
  • Sep 10, 2023
Common causes are:
  • TFI module
  • PIP in the distributor
  • Ignition switch in the column
Even in the heyday of the foxbody, it was common to carry an extra TFI in the glove box.
I've found common parts store parts not to be as reliable as the OEM parts, although much harder to find these days.
Reactions: 2000xp8, flynndawg and General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Sep 11, 2023
  • Sep 11, 2023
Running pig rich could always cause it to load up and stall.
This is why running the codes is step #1, although a lot of the common ignition related causes for this problem do not manifest as actual codes. It can at least help rule out some stuff.
Reactions: slow84lx
2000xp8
SN Certified Technician
Aug 8, 2003
8,063
1,647
194
NJ
Sep 18, 2023
  • Sep 18, 2023
I can't even remember the last time someone made a post and had a fuel problem.
Assuming it doesn't start right back up, follow the crank no start checklist.
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
  • brandyn200
  • Jun 20, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
