AOD Driven Gear
  • Thread starter Thread starter dcurtis
  • Start date Start date Feb 1, 2009
dcurtis
688
Feb 1, 2009
  • Feb 1, 2009
I have an aod tranny in my 91 and am installing some 3.73 gears next week and have been trying to figure out the correct driven gear to get to fix the speedo, as far as I have read it says that my tranny has an 8 tooth drive gear and with 3.73 gears and a 26 inch tire I will need the 23 tooth driven gear, basically I just want to be sure that I do in fact need the 23 tooth driven gear, does any one know?
I ask because all I can find is a 23 tooth that says it is for 410's and a 7 tooth shaft.
Where can I get the correct gear?
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Feb 2, 2009
  • Feb 2, 2009
with an AOD, the 23-tooth is what you want.
With a 5-spd, and 4.10's you'd also want a 23-tooth gear.
dcurtis
688
Feb 2, 2009
  • Feb 2, 2009
Thank ya thank ya
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Feb 2, 2009
  • Feb 2, 2009
Just to clarify for anyone else
90-later AOD is 8-tooth. 89-older is 7 tooth and requires a purple 21-tooth gear
monte87
876
18
49
new york
Feb 2, 2009
  • Feb 2, 2009
So say its 4.10's & AOD for a 91, then what?
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Feb 2, 2009
  • Feb 2, 2009
Then you are screwed because 23-tooth is as high as you can go.
Then you either live with it, or look into a speedometer recalibration box
monte87
876
18
49
new york
Feb 2, 2009
  • Feb 2, 2009
Wouldnt that 23 tooth gear-be the white one?
Thanks Ant
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Feb 2, 2009
  • Feb 2, 2009
Yes white is 23-tooth. It's not a Ford part...it's a chrysler part.
monte87
876
18
49
new york
Feb 2, 2009
  • Feb 2, 2009
Gotcha!!!! THX
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
Drivetrain Speedo gear ate itself
  • keel
  • Aug 15, 2024
Fox 5.0 Mustang Tech Aug 15, 2024
AeroCoupe
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
