AOD install ???'s
  • Thread starter Thread starter sand1man
  • Start date Start date Mar 27, 2004
sand1man
299
Charlotte, N C
Mar 27, 2004
  • Mar 27, 2004
AOD install ???'s and valvebody ???'s
I am putting in an AOD from a 89 Mustang, I've got everything in but when I went to connect the shifter linkage notice a slight problem, I bought the linkage arm from NPD but when connected if my shift selector says park the tranny is in first gear, on down the line until I get to 1rst which puts the tranny in park, I was able to use the cable from the mustang to correct this but it is somewhat unsightly is this normal for these trannies to be like this.
Also I am looking at getting either the Lentech Street Terminator valve body or the Strip Terminator valvebody which would you recommend and why, with these valve bodies would I have the same problem as above also this tranny has a 3500 stall
TobyGaff
211
Indianapolis
Mar 28, 2004
  • Mar 28, 2004
A lot of times on the tranny swaps, you have to take the shift arm off of the transmission and put it on upside down in order to get the shift pattern right. I have an AOD sitting here ready to go in a car, and it looks like that is what needs to happen.
12sec67
1,301
San Diego, Ca
Mar 28, 2004
  • Mar 28, 2004
i had to put the piece that holds the cable in place on the other side of the bracket to make mine work.
i heard the lentech valve body's work really well.
good luck
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Today at 9:08 AM
SchwarzStock
