Guys,
My AODE still is leaking. Passenger side rear. I have tried everything.
I replaced the pan and rubber gasket. I had come to the conclusion that the old pan was warped, or so I thought.
Well a new Ford pan and rubber gasket and still leaking. The mating surfaces were clean, bolts were clean and the pan wasn't overtightened.
With the front of the car jacked up, the tranny leaks rear passenger side.
Is there anything else on the passenger side of the AODE that could be causing the leak besides the pan?
Is there a overfill hose, how about the tran cooler lines ?
Any ideas would be great. Cause I am completely out of ideas. THANKS.
an, Pump seal, Pump gasket, dipstick
