  • 1994 - 1995 Specific Tech
aode to t5 swap
  • Thread starter Thread starter philly_blunt
  • Start date Start date Aug 6, 2007
P
philly_blunt
  • Aug 6, 2007
Well i'm getting tired of driving with od off cuz my od is shot on my aode. It slips alot when i am just cruising in od. So this leads me to my question, I found this ad on craigslist. http://detroit.craigslist.org/pts/390026711.html Will this 83 fit in my 94 w/o any major mods. Will I also need a 5speed computer too?
Zero_chance
1,244
Maricopa, AZ
Aug 7, 2007
  • Aug 7, 2007
I believe youll need to switch to a 5spd PCM or get a chip because the PCM controls the AODE and might go berserk if you take it away. Might cause driveability issues.
99FiveOh
2,051
20
99
J-Ville, FL
Aug 7, 2007
  • Aug 7, 2007
That setup won't do you much good. The clutch pedal assy will not work (that I know of) in 94/95 cars. Also, that 83 trans is a non world class I believe, so it's much weaker and prone to breakage than the later world class T5's. Also, you won't get the correct shifter bezel/boot for your car. Might want to keep searching.
1SLO94
14
Louisville, KY.
Aug 8, 2007
  • Aug 8, 2007
Not sure where you are located but I have my AODE from where I did the swap if you're interested? I'm right outside of Louisville KY. if that would be close maybe we could work something out ? If so just PM me!
Yes, the 94/95 pedal assembly is different from the fox style!!
Larry
fastgtfairlane
266
  • Aug 8, 2007
i also have a good aode that i will sell you if you need it. if you wanna do the swap to the t-5 i can give u a list of parts to get that will make the swap go smoothly.
P
philly_blunt
  • Aug 14, 2007
Well I found another t5 that came out of a 90 lx and it is a world class..... http://detroit.craigslist.org/pts/390083455.html
Could i use that bellhousing and then get a 3/8 spacer and a sn95 pedal assembly and t5 computer?
Zero_chance
1,244
Maricopa, AZ
Aug 14, 2007
  • Aug 14, 2007
FastGT, anyway you could post that info or PM it to me? Im considering this swap but I like to research it all first.
P
philly_blunt
  • Aug 14, 2007
http://www.fordmuscle.com/archives/2000/09/t5swap/index.php this is a pretty good article about parts you need. There is a write up on allfordmustangs.com but i can't find it right now. Fastgt, do you know any other sites or have the list of parts that you could post? Thanks
fastgtfairlane
266
  • Aug 14, 2007
i had an aode in my car before i did the swap. i did plenty of research on the swap before i did it as my car is my only mode of transportation so i wanted to make damn sure i had absolutely everything to do it.
the parts i bought used:
94-95 t-5 and bellhousing
t4mo computer
t-5 wiring harness- big square plug on passenger side on firewall near ac lines
94-98 pedals
upper and lower shift boots
parts i bought new
clutch cable ( recommend non adjustable from maximum motorsports)
firewall adjuster and clutch quadrant
flywheel and clutch ( proper bolts and dowel for press plate)
clutch fork and pivot ball in bellhousing
mercon tranny fluid for trans i believe it takes 3.5 or 3.6 quarts
i got the computer on ebay. the t-5 harness came from mpsautosalvage.com they also sell the kit as a whole but i spent about 2 months gathering the parts and saved about 400 bucks. you may need to change the tranny yoke on the driveshaft if you get a vibration. i personally got lucky and didnt have to change it. the swap is fairly simple. with air tools i did it in a day on the ground.
fastgtfairlane
266
#10
  • Aug 14, 2007
  • #10
you will have to remove about 1.5 inches on the front of the hole for the shifter to come through. i used some tin snips and it did a good job.
P
philly_blunt
#11
  • Aug 15, 2007
  • #11
Fastgt, If you don't mind me asking how much did you spend on the total conversion?
fastgtfairlane
266
#12
  • Aug 16, 2007
  • #12
i believe i spent about 1200 bucks on everything. i gathered parts for about 2 months though. i found the tranny on corral.net in the classifieds. you could probably find most of the parts on this site in the classifieds section. i also bought parts from ebay.
99FiveOh
2,051
20
99
J-Ville, FL
Aug 20, 2007
#13
  • Aug 20, 2007
  • #13
I did a conversion for a buddy for like 500 bucks, but he used a 4cyl T5. He beats the car some and it holds up nicely! I know it won't last forever, but it's a solution to get the job done on the cheap.
Zero_chance
1,244
Maricopa, AZ
Sep 24, 2007
#14
  • Sep 24, 2007
  • #14
Will a fox T5 work as long as I use the proper bellhousing?
fastgtfairlane
266
#15
  • Sep 25, 2007
  • #15
they say that a fox t5 will work but 94-95 t5s are easy enough to find. i would wait and find the 94-95 t5 cause i bet it will avoid possible headaches in the future.
Zero_chance
1,244
Maricopa, AZ
Sep 26, 2007
#16
  • Sep 26, 2007
  • #16
FastGT I should have asked you this before I posted a seperate topic. Will the clutch pedal assembly out of any SN95 work? I have a line on one from a 96 Cobra and just want to make sure it works. Got the PCM today already.
fastgtfairlane
266
#17
  • Sep 27, 2007
  • #17
it should work. i got mine from ebay. i dont know what year car it came off but worked fine.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Aod to t5 swap will it live?
  • 87slow.0
  • Nov 5, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2024
87slow.0
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
G
91' 2.3L AOD to T5 Swap Rear End Gear?
  • Gone Blue
  • Jan 5, 2024
  • 2.3L (N/A & Turbo) Tech
2K
2.3L (N/A & Turbo) Tech Mar 5, 2024
Gone Blue
G
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
