Aod to t5 swap will it live?
87slow.0
26
11
Indiana
Hello. I haven't posted here in quite awhile but I have a 87 gt vert that I've been slowly modding and running tnt in the last 2 seasons. I've got it down to a best of 13.29 @100.22 mph in the 1/4 and my best 1/8 mile pass was 8.33 at 79 mph with a 1.69 60ft..
Previously, it was going 1.68-1.70 60s consistently but the last few trips it was in the mid 1.7s even when it ran the 13.29. That was the 1st time I'd run the 1/4 in awhile due to no roll bar and bc of the e.t. I only got 1 pass. Anyway last Monday I laid into it pretty hard on the street and the Trans slipped on the 1-2 shift. I lifted immediately and it drove the rest of the way to and from work fine. On the way home I hit it again and it held it but it has me worried so I picked up a complete wc t5 swap minus the pedals/quadrant, cable, and I'll need a pilot bearing. I keep hearing from people, non mustang people so...., that it will not be as quick at the track with the t5. I disagree but we shall see. My worry is if it will hold up to the abuse the aod has for the last 4 years. I do maintain the car pretty thoroughly but i have not been easy on it for sure.
I've twisted a T5 into a pretzel in a driveway. :shrug:
It's a [good] street transmission, relatively smooth, and well built for OEM 302 Windsor torque levels.
Ape shifting at the track?
A couple things I've learned around here and personal experience, first and most important.to drag strip passes, the T5 don't like to be speed shifted, I have heard of a few things that help it live but it's costly.
Sticky tires are a threat too.
I most likely won't be no lift shifting it but I do run it on drag radials. I run 275/50/15 nittos 555r2 on the rear. Even with the aod it's absolutely no fun on a street tire. Car has a 4.10 rear gear in it, stock rear springs and lakewood 50/50 and strange 10 ways up front with again stock springs. I would like to at least still be in the 1.6-1.7 60 ft times.. are drag radials harder on parts then slicks?
Haven't swapped it yet. To be honest if my aod is OK when I change fluid and filter the t5 will rest in the corner of the garage til I need it. My aod only has about 25k ish.. miles on it. I had it built about 4 years ago. I called the shop and they said to change the fluid and filter bc from the heat from the converter it's probably just time. It has a non lockup 3500 converter..
The fluid hasn't been changed since the rebuild about 25k miles ago. Lots of street miles and a 1200 mile road trip at 75-80 mph at around 3k rpm for hours on end.. probably should have changed fluid n filter when I got back from that trip honestly.. going to try that first. It only slipped one time on the 1-2 shift wot for probably less then a second and I lifted.. hoping it's not done for. Bought the t5 swap just incase.
Reactions: Monkeybutt2000
