Are these times & mph low or is it just me?
1BAD93LX said:
Are there any tips that I can do to tune my combo in! I am really dissapointed wiht the mph! I was thinking of doing the following
Setting the Timing to 14 degree's
Fuel Pressure 40 psi
Cleaning my Pro M with some Electric spray cleaner
Changing to a 2 1/2inch Exhaust System from the the longtubes back!
Adding a 1inch Cobra Intake spacer
Doing a full tune up
NGK PLugs
Fuel Filter
PCV Valve
Synthtic Oil
Any other Idea's would be great, Just something to get the combo back to where is suppose to be! I am missing about 3 mph somewhere?
Any Other Idea's?
Those exclamation marks are killing me. :p
i would mess with the tune a little more while at the track and see what it likes. like someone else mentioned, crank the fuel pressure up above 40 lbs and see what it does.
i usually have my fuel pressure right around 45 lbs. my situation is a little different though, seeing that i have stock heads and injectors.
I feel a tune is in need or something is off.
I ran 82.38 MPH in the 1/8th and that was with stock heads, cam, headers, injectors, etc... on a warm night at a bad track.
You should be up around 87-88 range at least with your combo. Have you done a compression check? Is your car in perfect tune?
