Argh! Roller block?
  • Thread starter Thread starter eightyfour
  • Start date Start date Jan 15, 2004
E
eightyfour
125
Whitestone, NY
Jan 15, 2004
  • Jan 15, 2004
Well, all this time I thought I had a flat tappet block, being it's an 84. I was talking to the dude who I bought the car from (my neighbor), and he tells me six months later (today) that it is an early 90-something block. Yes! and No! It's cool that I have a roller block, but I had my cam all planned out as if it was a flat tappet block. I was gonna go with the XE268H, but now I can't. What cam should I go with? I would say E303... everyone loves and hates that cam. Comp XE cam? Which one? TFS 1? Crane? I will have a ~2500 stalland 60379 heads by the time I am ready to put in the cam. It's a daily driver that weighs 2954 lbs. Would like to see 12's. See sig for more mods.
Someguy80
305
Chicago
Jan 15, 2004
  • Jan 15, 2004
Tfs 1
maverick0716
3,924
Chilliwack, BC, Canada
Jan 15, 2004
  • Jan 15, 2004
I'm going to have a very similar combo to yours and I'm going with the TFS 1 cam.
C
chevyeater
438
  • Jan 16, 2004
post the casting no's off the block.it will tell yhe decade and the year and dat will be there to. casting date will be something like 5e17. the decade will be in big no's like D5AE. C5AE is 60; D5AE is 70's E5AE is 80's not sure for 90's blockthe day and date is 5 is exact year; e is is month; 17 is day. this will verify the block.the difference in the roller block is the lifter bore is extended to accomadate the long hyd roller lifter, you can still use the flat tappet in roller block. but no roller in non roller block without using reduce base circle cam.you could use same cam grind but in roller version.
G
goldbomb79
374
Indiana
Jan 16, 2004
  • Jan 16, 2004
or pull the lower intake and see if the top of the lifter holes are machined. if they are it's a roller block, if it's rough casting surface it's not
E
eightyfour
125
Whitestone, NY
Jan 16, 2004
  • Jan 16, 2004
thanks for all the help. where is the casting number? can i see it with the engine in the car?
maverick0716
3,924
Jan 16, 2004
  • Jan 16, 2004
Did he say it was out of an early 90's something Mustang? or just an early 90's 302 block? Because not all 90's 302's are roller blocks.
SmockDoiley
1,591
San Diego, CA
Jan 16, 2004
  • Jan 16, 2004
the first letter is the decade, the first number is year, the second letter is type of vehicle, and the next letter is type equipment. So E7TE would be 1987 Truck engine. there are different ways to tell if its a roller block. If the distributor gear is machined then its a roller, or if you see an xxx or yyy in the lifter valley. Of course, you could obviously see roller lifters maybe, or like he said about the machined tops. Why dont you ask the guy what it came out of. I'm assuming its carbureted?
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
