ARP studs with Trick Flow main cap girdle?
  • Thread starter Thread starter 68RustBucket
  • Start date Start date Jul 18, 2006
68RustBucket
119
Linwood, NJ
Jul 18, 2006
  • Jul 18, 2006
I need to know if purchasing a new set of ARP main cap studs (154-5401 on summitracing.com) is necessary when also purchasing a Trick Flow Main Cap Girdle (TFS-51500700). It seems that the girdle comes with some bolts, and I believe they are replacement main cap bolts. I want ARP studs, though, and I need to know if the ones I listed are long enough to use with the girdle.
68RustBucket
119
Linwood, NJ
Jul 18, 2006
  • Jul 18, 2006
... and then i think to myself, "why in the christ do i actually need a main cap girdle? i'm not racing this thing, and i doubt i'll be making the motor scream anywhere near 7k rpm, cause i want to keep it for a good bit".
So, with that said, lets just pretend i never asked
sportsroof69
231
Huntsville, AL
Jul 18, 2006
  • Jul 18, 2006
Main cap girdles only help hold the halves together after the block splits. Don't bother with one. Do a search on www.turbomustangs.com to find out how effective they are.
67Dylan
259
Phoenix, AZ
Jul 19, 2006
  • Jul 19, 2006
Yep... it's akin to wearing a seatbelt during a plane crash. Only used to keep you in place so they can identify you.
I'd skip that step and keep the tune good and don't rev her to the moon and you'll be safe enough IMO.
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
Engine and Power Adder Aug 19, 2026
Habu135
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
