At a loss!!!
  • Thread starter Thread starter artbillingsley
  • Start date Start date Sep 8, 2004
A
artbillingsley
10
Lafayette, LA
Sep 8, 2004
  • Sep 8, 2004
I have a 66 mustang coupe, I6 conversion to 302 V-8. It has an Edelbrock 650 cfm 4 bbl, Edelbrock Performer dual plane intake, HEI ignition, Gt40 heads with headers. The transmission is the C-4 auto. The engine runs fine when first started and does so until water temp reaches around 200 deg. Then the engine bogs down whenever I try to accelerate and runs very poorly (generally dying at stops unless I shift into neutral) at idle with or without a/c on. I've changed fuel lines to 3/8 aluminum tubing running them in the V-8 stock location and double checked to avoid all heat sources. I've readjusted the carb jets, and rechecked the timing. But, like I said, it runs perfectly when cold or cool. I'm at a loss to what to do next. HELP????
P
PONY XPRESS
143
  • Sep 8, 2004
Check for vacuum leaks.
R
Ronstang
1,294
Houston Texas
Sep 8, 2004
  • Sep 8, 2004
When cold the choke is on and artificially richening your mixture for cold running. You could be running lean when warm so check your mixture when at operating temperature. Usa a vacuum guage and adjust the mixture screws until you get the maximum vacuum.
O
Ozsum2
695
  • Sep 8, 2004
see if the choke is stuck.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
  • dan50
  • Jul 18, 2026
dan50
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
