Which one of these 3 intakes make the most sense for my 331 combo
from6to8
There's suction so I used that end O_O
1,904
143
94
Ok gents so I am still thinking about doing the 331 for the other car, the 95 GT/Saleen and seriously considering getting it built in TX and shipped. I know what I've read over the years and what some of you have said about using 302 parts on a stroker, ect. but the research has shown that you can get and make plenty of power for a nice street car that will not see the track and be mostly a weekend driver (one of 3 and potentially as many as 5 cars since I still want a fox or 2) :D.
I have talked to him a good bit about matching a combo and I'm going to follow his lead but I'm asking you guys here on your opinions between 3 intakes that I'm thinking about. I want to point out as well that he builds dirt cars but has build a lot of other stuff as well but I think from talking to him over the years that he hasn't done a lot of fuel injected mustangs but many carbed ones. I'm not sure how many combos he's had to put together F.I. wise but know for what we've talked about he's mentioned long runner intakes vs short runners and how they affect things. Just did a quick google search anyway and it seems that the long runner intakes are nice for the street and down low where the short runners are more mid to upper. When I called Edelbrock to inquire about the performer 2 they couldn't tell me nor was there really any info online on rather it's a long or short runner intake. I do run that intake and have for years on my 302 combo.
For the 331 I intend to use a 75 mm opening intake in either another performer 2, a TFS R (not box), or even a Holley efi 8.2 deck. I'm not that familiar with the holley and not sure if it's as tall of an intake as the ones for a 351 and I definitely don't want to go too crazy with needing that high of a cowl hood either. I believe years ago researching the rpm 2 vs the Tfs R I think the rpm 2 was around an inch or so lower in height IIRC.
As for the specs the rpm 2's range is from 1500-6500 rpm and the Tfs R is 2500-7250 and actuall it appears from looking at the holleys, the smallest opening they offer is maybe a 92 lol so I know that's out of the range that I'll need for my combo. I will say also that it seems that the performer will be a better all around intake for my application as far as matching the intended use.
Actually thinking about running a Brodix 17 degree 165 cc head with 1.94 and 1.54 valves, he'll grind a custom cam for the setup, 70 tb, 75 or 80 maf, 36 or 42 lb injectors, and probably 1 5/8 LT's. I think I'll be really happy with around 350 rwhp if I get there. If I get to around 330 I believe for how I'll drive the car and what I'll be doing, I'll be happy as well :LOL:.
After all I've been around 300 rwhp for a long long time with my current 302 mostly over 100k miles when I first did the combo back in 05 but really the car hasn't run it's best till around 2014 with another tune. :poo: that was only 8k miles ago as the car got hit in 2015 and sat til 2019 when I took it apart. I put the engine in my 94 Cobra in 2021 and went to LT's, 3.73's, X, and a pypes bomb free flowing catback vs shorties and the flowmasters with an X.
Texting him a minute ago he said the Brodix 17 degree will murder that AFR. He said to do a 1 1/2 inch pimary and a 42 lb 4 hole is too big. He'll buy the heads bare as well.
I replied that I'll research the 1 1/2s as I haven't seen or heard of anyone running those and I didn't think it would make that much difference lol.
He replied " The :leghump: it isn't. You guys don't understand gas speed. Yall think it's all about flow cfm numbers, No it's :leghump:ing not. The engine cares about 5x more for gas speed than cfm in the exhaust port and it cares 10x more about air speed in the intake port than it does raw cfm numbers the port can flow. Without port velocity, cfm is meaningless to the engine. The smaller the pipe you can make power with, the harder the engine will accelerate and the more driveable it will be because it will make more torque where you drive. When we are dealing with sub 550 hp engines and especially sub 450 hp engines, this is exactly why I can replace a 1.600 diameter ex valve with a 1.500, and regardless of the flow number change on the flow bench, the engine gains tq and hp every single time. Along with that the customer always comments how much more drivable the car is, even when all we changed was simply the new ex valve seat and smaller ex valve. "
There's more but too much to type lol I might add it later when i reply from the phone and can speak to text lmfao. But all in all just wanted to know you guys opinion on the intake but I'd think the rpm 2 would suit best overall given the overall combo and matching.
Check out Richard Holders(?) Not sure of spelling, YouTube videos, he test box r and Tfs r.
I believe he made more power everywhere with the streetburner, I know sounds Cray Cray ,but he dynos a :poo: load of ford strokers.
If you're talking about that trick flow flat intake the I believe it's the first level they make cuz I think they make a street burner and a track heat, but I don't like the only Intex I even like and I know it's not all about likes all the time but I've never liked the look of that intake and I would probably just do an rpm2 over it but when I get time I will check out the specs and everything on it.
Yeah that guy Richard test alotta intakes on sbf. He states the most c.f.m. doesn't make the best h.p and tq.,
Oh yeah I know that and I stated what my boy in Texas said about everything that affects flow and speed velocity, etc etc. So yeah when I was asking about the Intex I wasn't necessarily talking about the flow numbers or the cfms of the Intex in particular but better overall for my setup. I forgot to mention the system and so it will likely be between those two intakes the system Acts or the performer too and since I have a performer too on my 302 I like to go with the system Max maybe. And I use speech to text when I'm replying on mobile so I know it messed me up SMH
Reactions: nickyb
Whichever intake you go with (Edelbrock Performer RPM IIor the Holley Systemax) have the lower ports matched to the cylinder heads. Guy that ported my heads did that and cleaned up the runners. When the motor was put together they were almost a perfect match.
I would suggest the TFS 170 11R heads or AFR Renegade 165 heads. You don’t hear of many guys running the Brodix heads but if he can make them work that’s all that matters.
I currently run Edelbrock Performer RPM heads that have been worked over (had them for years and bought them cheap) on the 331 in my Coupe. The power drops off after about 6400 rpm but is a slow drop and the motor still wants to pull past that. If I can ever convince BluePrint to sell me one of their four volt mains I am going to get different heads.
Reactions: from6to8
I currently run Edelbrock Performer RPM heads that have been worked over (had them for years and bought them cheap) on the 331 in my Coupe. Motor runs out of cylinder head after about 6200 rpm according to my builder and the dyno indicates this. If I can ever convince BluePrint to sell me one of their four volt mains I am going to get different heads.
What's going on Aero? First an update on the 94 well I went back to the tuner a few weeks ago and so far so good with the issue being resolved. Now since that Friday I really haven't driven it but once and maybe it was that Saturday or Sunday but it wasn't too hot hot and since those 2 days it has been hot, but raining some every day literally. I do not like driving my cars in the rain especially when they are decently clean lol. So whenever we get back to nice Sunny days and especially on a weekend I will take her out. I'll follow up overall on how it's doing and if my hp and torque were affected overall in what he did/change.
He is a Brodix dealer and Dart as well and he's done a lot of different heads and combos and such and says he gets his heads bare and builds them. He wants to use a 1.94 and a 1.54 vs a 2.02 and 1.60 and for everything he's told me over the years I'm willing to trust him on his setups. All in all though I believe from what he's told me , if I went with another head he still wants to get them bare and build them vs right out the box.
I did some reading up on 1 1/2 headers and didn't see a lot of options to buy. I told him last night that I didn't think it would be much difference in running the 1 1/2 vs the 1 5/8 for the combo and he said he knows it will lol. But I think I'll be able to live with and he'll be able to still make that combo work well without the recommended 1 1/2's. He did ask me he said " Do I know the power level a single 1 1/2 inch pipe can support" and I said no. He said 80 hp and so 80x8=640. Another person said to me that considering the Brodix just keep in mind that they have 1/2 " raised exhaust ports so from my reading up I might have to run an adapter plate to be able to use a bbk 1 5/8. Bbk are going to be easily available and I actually put some on my 94 when I dropped the engine in in 2021.
If that’s the case then why do the heads up racers making 900 fwhp on stroker bases 351’s run 2” and larger primaries?
I think what he is trying to convey with that statement is the velocity of the air coming into and out of the combustion chamber is very important to the way a motor makes power and where it will make power. We should all agree on that.
He sounds knowledgeable and you should listen to him on the combo.
These are for a 79-93 but they might work on a 94/95 car. I cannot say for sure but one of the other guys on here will know.
