  • SN95 4.6L Mustang Tech
Auto fluid type
  • Thread starter Thread starter Ram5773
  • Start date Start date Sep 4, 2006
R
Ram5773
66
Melbourne, Florida
Sep 4, 2006
  • Sep 4, 2006
I did a search and didn't find the answer that I was looking for, my tranny has about 40,000 miles on it and it's diffucult to tell if it has been changed from the previous owner. I found the Mobil spec 5 tranny fluid is that any good? or should I stick with the Ford stuff?
I going to do a complete drain on the tranny and install a tranny cooler, any other advice that you guy's can give me while i'm doing this. I'm probaly going to get a tranny fluid bath
Thanks Ram
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 4, 2006
  • Sep 4, 2006
you have to use a Mercon V approved fluid. the Mobil 1 ATF has just been approved for Mercon V aplications. it is a very good fluid and i use it in both my fords power steering, my mustang's trans and my grand marquis automatic trans.
you will need about 16qts to do everything correctly. make sure you change the filter and consider installing the export 4R70W pan that has a drain plug. it will make future services a lot easier. heres the part number for the pan F8UZ-7A194-AA
M
my95gtstang
76
Chesapeake, VA
Sep 5, 2006
  • Sep 5, 2006
i was thinking about doing this on my stang cuz shes gettin old and i doubt anyone before me did it. so what all would i need because i have no idea what to get to do everything.
DropTopPony
Noob Slayer
2,570
south jersey
Sep 5, 2006
  • Sep 5, 2006
i need one of those pans...its a direct fit?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Sep 5, 2006
  • Sep 5, 2006
The Ford Racing drain pan for the 4R70W has a drain plug PLUS cooling fins AND an extra two quarts of capacity...
R
rs-turbo
397
Orlando, Florida
Sep 5, 2006
  • Sep 5, 2006
Amsoil has had a synthetic ATF meeting Mercon V for many years now.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 5, 2006
  • Sep 5, 2006
true, and amsoil is a very good fluid. i just know in my area the Mobil 1 ATF is a lot easier to get my hands on.
the FRPP pan is another option. last time i checked, the iimport pan that is a direct bolt on was about $35 from a dealer.
R
Ram5773
66
Melbourne, Florida
Sep 5, 2006
  • Sep 5, 2006
Thanks
Thanks for you feedback, I'll get a pan too but nobody mentioned the Ford tranny fluid. Will the Mobil 1 give me any future tranny problems?
Thanks again
Ram
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 5, 2006
  • Sep 5, 2006
mobil 1 wont give you any problems. last time i checked the ford tranny fluid wasnt a synthetic and cost just as much as M1 ATF.
R
Ram5773
66
Melbourne, Florida
Sep 5, 2006
#10
  • Sep 5, 2006
  • #10
Thanks bdcardinal, I go and get some Mobil 1 fluid and that pan.
Thanks Ram
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 5, 2006
#11
  • Sep 5, 2006
  • #11
just remember that the import pan is literally the same size as stock. they used it on domestic U-Haul and most trucks that were imported. that price is just what ive seen, it might be more. the huge advantage to it is the drain plug from the factory.
R
rs-turbo
397
Orlando, Florida
Sep 6, 2006
#12
  • Sep 6, 2006
  • #12
If you use a fluid that meets the specs that are required, any fluid, then you should be okay. Once you find the fluids that do, then the choice is which one you feel will do the better job. Synthetics tend to perform better than petroleums, although some synthetics these days are petroleum based. You should be safe with both Amsoil and Mobil 1, both still using a PAO base stock with most of their fluids.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • Gulftown980x
  • Jul 29, 2026
squeak93
