I have some AOD parts left over. I sold most, but have a few left + the tranny. If you are local to Boston, PM me.
PS, i'm not really 100% sure if the computers need to be swapped. The issue is mostly the o2 harnesses. I know a AOD o2 harness will not work with a manual computer, but unsure if it will work the other way around.
Either way, you'd basically need the AOD comp and an AOD o2 harness. I don't think you need to change the in-car trans harness as you can let the NSS p;ug for the top of the t-5 just dangle and it won't affect anything since the AOD comp doesn't look for it.
Other that that, just plus the AOD harness into the body harness and make sure you jump out the DARK colored plug on the clutch pedal with the factory jumper or a 10A fuse taped in place. Everything else is purely mechanical.
