  • SN95 4.6L Mustang Tech
autometer fuel pressure gauge removal
  • Thread starter Thread starter Mustang4119
  • Start date Start date Jul 13, 2007
M
Mustang4119
162
  • Jul 13, 2007
I see that it has the adapter that goes into the schrader valve. Do I need to get a new schrader valve for my 00GT? If I unscrew that piece from autometer wont it spray out fuel and has no valve like it is stock? I unplugged the gauge that goes to it and took out guage, but left that adapter sender unit in. Can I just unscrew it?
M
Mel96GT
255
San Diego
Jul 13, 2007
  • Jul 13, 2007
Yes you can unscrew it but you will need a Schrader valve to replace it. It looks like a typical bicycle tire air valve. Not much fuel will spill out when you unscrew the fitting and replace it with a Schrader valve. Just make sure you use a good sealant or it will leak. I used teflon tape rated for gas lines to seal the threads on my adapter since nothing else worked. Another option is to place a threaded plug in its place. You may be able to raid a wrecking yard for a Schrader valve. Those electrical fuel pressure setups are pricey, why are you removing it?
M
Mustang4119
162
  • Jul 13, 2007
selling car and selling the blower. Ya i called ford and you have to buy the whole fuel rail?? What happened to my stock schrader valve when the person installed the gauge? I dont get it. Where can i get a schrader valve? i thought i could just unscrew the adapter and be done with it. Its not underneath it?
M
Mel96GT
255
San Diego
Jul 14, 2007
  • Jul 14, 2007
Nope, the Schrader valve is not under the adapter. You will need one OR if you can't find one just use a threaded plug to block the hole. No one will be the wiser.
M
Mustang4119
162
  • Jul 14, 2007
what size is the threaded plug? They dont sell those kind of things at home depot a schrader valve
M
Mel96GT
255
San Diego
Jul 14, 2007
  • Jul 14, 2007
I don't know the thread size so you would have to remove the adapter and go check who has a threaded plug the same size. Home Depot def does not carry a Schrader valve. You're in luck though. I have a spare from another fuel rail. If you want it for just the shipping costs PM me. Later.
  • Gulftown980x
  • Jul 29, 2026
squeak93
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
