Back four intake runners wet. Need advice.
  • Thread starter Thread starter daddystang
  • Start date Start date Jul 2, 2007
daddystang
185
  • Jul 2, 2007
Guys I've had this problem for a while. When I had my intake off a month ago I noticed the back four lower intake runners were wet, yet the front four were dry. I was cleaning the engine yesterday, and noticed that the back half of the phenolic spacer was wet, and the front half was dry (back half was a dark brown color, the front was the normal looking light brown color). I did some searching, and found that this is probably a problem with the PCV system which is stock right now. I read that I could put a air/oil seperator on the PCV hose, but some say this isn't a fix, rather just a bandaid. Is there anything I can do to stop this permanently. Thanks for any thoughts or help you can provide.
The car feels like it is running/idleing really good also.
Thanks in advance...
1991vert
1,103
Ludlow, MA
Jul 2, 2007
  • Jul 2, 2007
my back 2 were still wet after an air/oil seperator...subscribing
vristang
4,933
101
124
Seattle
Jul 2, 2007
  • Jul 2, 2007
I have no way to explain why some runners would be wet with oil, and others wouldn't.
I would be interested in hearing any theories on this...
The separators are great for confirming that the pcv is the source of oil contamination in the intake.
There is nothing wrong with hooking one up. And it will give you an idea of how bad the situation is...
jason
daddystang
185
  • Jul 2, 2007
Thanks guys. I'm thinking I'll try the separater. I wonder if a breathable oil filler cap would help reduce the pressure in the crankcase (if that's what's causing the oil to go past the pcv valve). Any thoughts on that guys?
Thanks again...
vristang
4,933
101
124
Seattle
Jul 2, 2007
  • Jul 2, 2007
Thanks again...
If you use a breather with the pcv still in place, then you will effectively create a vac leak.
Fresh (un-metered) air enters the crankcase via the breather, then gets pulled into the intake through the pcv...
It doesn't sound like you need to worry about increasing capacity that much...
Do you still have the baffle on the passenger valve cover?
jason
98BLKGT
322
Chicago area
Jul 2, 2007
  • Jul 2, 2007
My guess would be its because the PCV line comes into the intake on the right side.
vristang
4,933
101
124
Seattle
Jul 2, 2007
  • Jul 2, 2007
That is a sound theory...
(my mind always seems to focus on my box upper intake, which wouldn't produce the same results as a long runner intake. Especially when you consider the location of the pcv inlet to the manifold)
I'm satisfied with 98blkGT's theory...
Anyone wanna argue
jason
daddystang
185
  • Jul 3, 2007
Nope, I don't have a baffle on the valve cover, and I agree that it's because the pcv runs to the back of the upper intake. 98blkgt, my gasket looks exactly the same. You would think there would be some way to put a "T" fitting in the PCV hose, and then run a hose to one of the valve covers to let the oil coming up through the PCV valve to then drip back down into the motor. In a sense it would be like using a separator, and giving the oil a route back to the motor rather than just filling up in the separator. Do you guys think something like that would work, or would that also create vac leak. Just turn'in the gears in my head. Any thoughts?
Thanks guys for your input.
Joe
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
