Back up lights
  • Thread starter Thread starter meweehaa
  • Start date Start date Mar 26, 2004
meweehaa
202
Northeast PA
Mar 26, 2004
  • Mar 26, 2004
I have a 69 with a T-5 I don't currently have back up lights and was wondering if anyone had this setup with functional lights not using a toggle switch.
big block 460
54
  • Mar 26, 2004
yeah me too there is't any on my 65 eather don't know were to hook them up iam in the same shape without useing a toggle !!
slapper
447
  • Mar 26, 2004
Driver's side of transmission- 2 pronged switch. Looks like a small mushroom.
68Coupe289
234
Lexington, KY
Mar 26, 2004
  • Mar 26, 2004
Mine have never worked (toploader 4 speed).
Glen's 1965 5.0
477
Tomball,Texas
Mar 26, 2004
  • Mar 26, 2004
The switch is as describes as the two-prong switch on the driver’s side of the T5. I found it best to salvage a plug from a donor car and then tie it into your harness. Mine has worked flawlessly. To verify the switch is working just jumper the two reverse light wires. They should come on.
meweehaa
202
Northeast PA
Mar 26, 2004
  • Mar 26, 2004
I have been looking for a schematic for my neutral safety/rev light harness. Can't seem to find it. I have the Ford 5 book manuals so if it is in there could someone tell me where? Four wires but they were spliced together years ago when there was a bad switch on the then c-4. Thanks, David
I
INDSKYS
245
CALIFORNIA
Mar 27, 2004
  • Mar 27, 2004
I USED TWO INSTRUMENT SENSOR SNAP ON ENDS TO ATTACH MY REVERRSE LIGHTS TO THE T-5.YOU DO HAVE TO DRILL THEM OUT SLIGHTLY TO FIT THO AS THE T-5 TERMINALS ARE A TAD LARGER THEN SENSOR POSTS.FOR THE NEUTRAL SAFETY I USED A ALWAYS OFF PULL SWITCH FROM A TRACTOR SHOP RIVETED IT TO THE CLUTCH ARM UP HIGH THEN ATTACED TO THE FIREWALL WITH A LIGHT SPRING SO THE PEDAL MUST BE IN TO START THE CAR.
meweehaa
202
Northeast PA
Apr 3, 2004
  • Apr 3, 2004
I went to the junkyard and for $2.99 I got the harnesses I needed and spliced them in and I have power and everything on the back up lights. The only problem is finding an 1142 lamp. Autozone doesn't carry them so I suppose Kragen doesn't either. The neutral safety witch is working as well. I put the car in neutral and bang it starts right up. Any other place in the shift pattern and NOPE! Thanks for your help guys.
big block 460
54
  • Apr 3, 2004
yeah i notice that my car starts in drive too were is the neutral safty switch?
i didn't see a rev. switch on drivers side ,, i think i have a c4 tranny though does that make a difference ?
meweehaa
202
Northeast PA
Apr 3, 2004
#10
  • Apr 3, 2004
  • #10
the connection for your neutral safety switch is on the firewall inside engine compartment. Check to see if there are four wires going to it and that they aren't spliced together. That was my problem.
MustangMatt1966
1,004
Orlando Fl.
Apr 4, 2004
#11
  • Apr 4, 2004
  • #11
screw backup lights, no one needs them, i have a t5 and mine dnt work ha ha
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
Light bulb for under hood
  • mustangfiveo198
  • May 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 8, 2026
mustangfiveo198
