  • 1994 - 1995 Specific Tech
Bad Intake Backfires!!!
  • Thread starter Thread starter Pai
  • Start date Start date Feb 11, 2009
P
Pai
12
  • Feb 11, 2009
Hi guys!
I have a 1994 Mustang 5.0
Trick flow heads
Stage one cam
Roller rockers
Headers
Stock H with 4 cats
Underdrive pulleys
Cold air
65mm throttle body.
And for days now, Ive been searching this site on a problem i've had and thought I fixed.
I hate starting threads like this by posting a problem as my first post on a forum, but I am in desperate need of some advice!
Here is my problem.
Timing is at 16 degrees, and when I go wot it will POP from the intake. The ONLY way to fix it was to put the timing on 20 degrees advance. WTF. Thats not right.
ANYONE have ANY idea as to what can be wrong?
Also, when the motor gets hot, a little above normal, it drives like crap at times.
I dont understand why When I advance the timing, it goes away....
Other then that, the car drives fine, until it gets really warm
I was just thinking, and At first I thought maybe its the fuel pump causing a lean miss, my fuel pumps gets pretty loud. But, That wouldnt explain me advancing the timing and the pops go away, right?
What are the chances that the rockers need adjusting? Their kinda loud.
I appreciate Any input. Wether it be negative or positive! lol
Thanks fellows. :SNSign:
Dino Dino Bambino
1,673
90
79
Cyprus
Feb 11, 2009
  • Feb 11, 2009
You might wanna check the harmonic balancer. It's just possible that the outer ring has spun a few degrees so what you think is 20*BTDC base timing might be more like 8 or 10. The popping from the intake and the engine running hot could be due to the timing being overretarded.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Feb 11, 2009
  • Feb 11, 2009
agreed , change the balancer and set timing to 10-14 degrees
P
Pai
12
  • Feb 11, 2009
I will try that asap!
Any other ideas before I tackle this thing down?
desertcox05
379
south atlanta
Feb 12, 2009
  • Feb 12, 2009
another + for harmonic balancer. you'll need to rent a puller from auto zone or advance. don't forget to remove the big washer inside the balancer when you remove the bolt. you might also need to raise the radiator up to clear the puller. leave the car in gear with the e- brake set. that bolt has over 100 lb.ft. of torque on it. so use a 1/2 impact or a long breaker bar to get that mother loose.
P
Pai
12
  • Feb 15, 2009
Okay, so a couple updates.
Few days ago, after I would advance to 26, drove Perfectly and best it has ever had. But come on, 26 degrees? Wtf. Unreal.
Today, I put on a new harmonic balancer and the SAME THING.
So, I was thinking, maybe when the trick flow cam was put on, the timing was off retarded a tooth, so you have to advance ignition timing to compensate. But I wouldnt think thats possible is it???
Also, Im matching up the timing mark from the balancer onto the pointer that says "time" Is that correct?
Any help would help, thanks! :SNSign:
desertcox05
379
south atlanta
Feb 16, 2009
  • Feb 16, 2009
the dizzy may be off a tooth also. you'll need to pull it out and rotate the rotor 1 tooth and put it back in. make a mark on the base of the dizzy and intake manifold so you know where you started from and make note where the rotor is pionting for the same reason.
P
Pai
12
  • Feb 16, 2009
So, mark the dizzy where it is, then turn the tooth each side one and see if that works?
If I was to put cyl. 1 on TDC and then check the rotor, would that tell me if my dizzy is off a tooth?
desertcox05
379
south atlanta
Feb 16, 2009
  • Feb 16, 2009
that's basically what the timing light is doing. lift the dizzy out and rotate the rotor 1 tooth and put the dizzy back in the samt spot. the rotor will now be pointing to a different spark plug. now time as needed.
P
Pai
12
#10
  • Feb 16, 2009
  • #10
So, Start by turning one tooth to the left. and check timing?
P
Pai
12
#11
  • Feb 16, 2009
  • #11
sounds like this
Do you read the timing pointer at the end or in the circle? - Ford Mustang Forums
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 16, 2009
#12
  • Feb 16, 2009
  • #12
That's actually a myth. There is no such thing as a distributer being a tooth off. Sometimes if it isn't put back in to mesh with the teeth it has been meshing with for an extended period of time it will create a wining noise, but it has nothing to do with ignition timing.
Kurt
desertcox05
379
south atlanta
Feb 17, 2009
#13
  • Feb 17, 2009
  • #13
my bad. that info is for limited travel dizzys. oops
donkey_punch
565
northern****ingjersey
Feb 17, 2009
#14
  • Feb 17, 2009
  • #14
are you removing the spout before you try adjusting the timing?
i know it's sounds stupid, but you'll be surprised how many times a small detail like this is overlooked.
P
Pai
12
#15
  • Feb 17, 2009
  • #15
Yep. Lol.
M
mackey
1,284
Beverly, Massachusetts
Feb 18, 2009
#16
  • Feb 18, 2009
  • #16
It is timing related obviously. First thing to do is to check to make sure your timing is advancing with the spout in. Another is to check your plug wires. Are they all correct?
P
Pai
12
#17
  • Feb 19, 2009
  • #17
Yeah.
I remove spout to change timing, then put back in and make sure it advances. Quadruple checked wires.
Just tried to completely reset the timing.
1) remove #1 spark plug-passenger side towards front bumper
2) turn crank with ratchet while holding finger over spark plug hole
when you feel a mass amount of air trying to escape from the plug hole look at your balancer- you should be approaching TDC.
3)stop turning crank when TDC aligns with pointer
4) install distributor with rotr pointing towards the #1spark plug wire on the cap.
start engine & check timing (with the plug removed)
5) lock down distributor and you're good to go!
What I dont understand is, should I just turn the dis. to where its pointing at number one?
I did that, and Im having the same exact problem.
P
Pai
12
#18
  • Feb 19, 2009
  • #18
I read at least fifteen threads of this happening to other people, but they NEVER post how they fixed or even ever fixed the problem. See, I dont know if my base timing is at 10, 20, or even 30.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
