bad shake at high speeds
  • Thread starter Thread starter whtnotch
  • Start date Start date May 1, 2008
W
whtnotch
123
Chicago
May 1, 2008
  • May 1, 2008
I was on the highway the other night and decided to bury the needle for unknown reason...Car was shaking like crazy.Car has a TKO swap with aluminum D/S .is it possible the D/S was installed incorrectly? is there a certain way it goes?I know the D/S is supposed to reduce shake.what can the problem be?
state trooper lost
Jaswir
578
Orlando, FL
May 1, 2008
  • May 1, 2008
Could be a # of things
U-join on drive shaft
Front rotor bearings
tires unbalanced
Trans mount
Engine mount
What kind of vibration is it?
Does the shifter shake bad?
At what speed does it start to shake?
89CobraGT
113
Winnipeg manitoba
May 1, 2008
  • May 1, 2008
I had the same thing happen to me last year on the highway the d/s bolts were just loose check that first
W
whtnotch
123
Chicago
May 1, 2008
  • May 1, 2008
I think the shake was only violent when car was being givin gas.once I let off it kinda got better.
trans mount?what are the ways to fix i got an energy trans mount with the needed x member.
W
whtnotch
123
Chicago
May 2, 2008
  • May 2, 2008
bump
9
90bluecoupe
76
Abingdon md
May 2, 2008
  • May 2, 2008
D/S bolts
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Engine Backfiring and Shaking Pony
  • Krazykyle44
  • Mar 15, 2021
2K
Fox 5.0 Mustang Tech Mar 17, 2021
General karthief
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Codes 32, 67, 82, 95 And Other Problems
  • LX Dave
  • Jul 2, 2017
8K
Fox 5.0 Mustang Tech Oct 11, 2021
jrichker
H
87 T-bird W/92 5.0 Swap High Idle
  • hjbjzj
  • Sep 25, 2017
3K
Fox 5.0 Mustang Tech Sep 26, 2017
hjbjzj
H
